Fuel issue - Mustang Evolution
Old 03-03-2013, 01:45 PM   #1
336badboy's Avatar
Fuel issue
Okay just got my car and got a issue at high Rpms I'm losing power I'm thinkin its a loss of gas
336badboy is offline   Reply With Quote
Old 03-04-2013, 08:45 AM   #2
336badboy's Avatar
Well today it shut off n not cranking I think imma take off filter n see if line clogged
Old 03-05-2013, 11:41 AM   #3
336badboy's Avatar
Fuel pump shot but suppose to be a new one
Old 03-06-2013, 04:34 PM   #4
Cornkush's Avatar
with the car sitting ther push the fuel pressure release valve ( small valve stem similar to a tire) on the fuel rail and see if it has fuel pressure keep a rag around for obvious reasons. if it has pressure sitting off then try it with the key in th run/start postion the pump should be pressurized. still has pressure then pump is functioning.
---------- Post added at 06:34 PM ---------- Previous post was at 06:31 PM ----------
ah just saw last post sorry
Cornkush is offline   Reply With Quote
Old 03-06-2013, 07:38 PM   #5
336badboy's Avatar
Thanks I'm still gonna checc cause I'm working solo
Old 03-07-2013, 12:30 AM   #6
Cornkush's Avatar
Same thing I'm currently dealing with fuel pump
Old 03-07-2013, 08:01 AM   #7
336badboy's Avatar
So yours is shot as well
Old 03-07-2013, 08:19 AM   #8
Cornkush's Avatar
Yes and it's had a rod bearing that is knocking as well
Old 03-07-2013, 09:52 AM   #9
was gonna say check the fuel pump voltage and see if it is bad at higher rpms
Old 03-07-2013, 10:07 AM   #10
336badboy's Avatar
That's how it was but now I'm getting no gas to engine whatsoever
---------- Post added at 12:07 PM ---------- Previous post was at 12:05 PM ----------
Damn I'm checcin on another engine now the one I got is fine but I want another ready for boost but then again I'm taking it from auto to manual
Old 03-08-2013, 09:26 AM   #11
Cornkush's Avatar
Ever get the pump?
Old 03-08-2013, 09:33 AM   #12
336badboy's Avatar
Ever get the pump?
Getting today checcing around or prices
Old 03-08-2013, 10:03 AM   #13
336badboy's Avatar
On top of that I just locced keys in the car wtf
Old 03-08-2013, 10:03 AM   #14
Cornkush's Avatar
Coat hanger
Old 03-08-2013, 10:17 AM   #15
336badboy's Avatar
Coat hanger
Sadly battery dead smh
Old 03-08-2013, 10:24 AM   #16
Cornkush's Avatar
Ah sorry to hear that lol I have billet door locks so i can always grab em with a hanger if I have too lol
Old 03-08-2013, 10:24 AM   #17
336badboy's Avatar
Smh my bro got in convertibles might not be the way to go
Old 03-08-2013, 11:27 AM   #18
336badboy's Avatar
Just got it $109.99
Old 03-09-2013, 12:25 AM   #19
336badboy's Avatar
Fixed it but now new issue tires dry rott and gastank has a major leak
Old 03-09-2013, 09:33 AM   #20
Cornkush's Avatar
Where did you get one for 109? But sorry to hear that
Old 03-09-2013, 03:01 PM   #21
336badboy's Avatar
Yea got new tires the gas tank leaks on side where top and bottom connect, and I got it from auto zone orileys was the same price just not in stocc
Old 03-09-2013, 03:13 PM   #22
ksrumbel's Avatar
I just tried to start mine today after having it garaged since November... No fuel pressure also. Looks like I will be dropping the tank tomorrow to change the pump.
ksrumbel is offline   Reply With Quote
Old 03-09-2013, 05:32 PM   #23
336badboy's Avatar
First make sure ya switch is pushed down n didn't reset
Old 03-09-2013, 06:08 PM   #24
ksrumbel's Avatar
I'm not really sure what you mean by that.
Old 03-09-2013, 06:23 PM   #25
ksrumbel's Avatar
I just read up on what you were referring to. The inertia switch. What would cause that to trip? I've read usually accidents.
Old 03-09-2013, 06:34 PM   #26
336badboy's Avatar
I have had systems flip mine n hard spots in the road,
Old 03-10-2013, 07:51 AM   #27
ksrumbel's Avatar
I'm going to have to check that out today. I don't know why it would have flipped. The car ran when I parked it for the winter and now it doesn't want to start.
Old 03-10-2013, 09:23 AM   #28
02 360R's Avatar
I knew a lady that parked her focus in a driveway that was steep for about an hour and when she tried to leave, the car won't start. The switched flipped. What's strange is she parks there all the time. Just this time, the switch flipped. Thanks to roadside, otherwise, she was getting it towed back to the Ford dealership.
02 360R is offline   Reply With Quote
Old 03-10-2013, 09:38 AM   #29
ksrumbel's Avatar
I check the switch. It seemed to be pushed down all the way. So I am left scratching my head. The car ran fine before I parked it for the winter. I don't know why the pump would just go bad from sitting.
Old 03-10-2013, 10:50 AM   #30
336badboy's Avatar
Maybe its the relay I'm not sure mine was covered with trash and now its acting up again and I just put the new one in two days ago I think its more than just some trash in the tank
10:02 PM
