How low can I go? - Mustang Evolution
Old 03-03-2013, 06:19 PM   #1
MustangGT02's Avatar
How low can I go?
Im looking at two kits from eibach. My main question is what kit will work with my 17x9 with 275/40R17? I want handling and dont care about ride, Im planning on do autocross and drag racing a lot more this summer and I only drive about 5 miles in a day so I can live with bad ride quality.
Heres the kits:
1994-04 Mustang Eibach Pro-System Plus Suspension Kit at LRS - Free Shipping!
1994-04 Mustang Eibach Sport System Plus Lowering Spring Shock And Swaybar Kit at LRS - Free Shipping!
I will also be getting new quad shocks, upper and lower rear control arms and caster camber plates.
Thanks for the help!
MustangGT02 is offline   Reply With Quote
Old 03-03-2013, 06:37 PM   #2
02 360R's Avatar
I have the eibach sports line and the pro damper shocks and struts. It dropped nearly 2 inches and the ride quality sucks, but it's not that bad. It definitely handles like a sports car should now.
02 360R is offline   Reply With Quote
Old 03-03-2013, 06:41 PM   #3
That my second question which kit has better handling?
Old 03-03-2013, 08:55 PM   #4
02 360R's Avatar
I only know about the sports line. And the handling is awesome.
Old 03-03-2013, 09:03 PM   #5
1slosix's Avatar
pick one...auto cross...or drag racing...building a suspension is based on the sport you wish to compete...the setup you'd want for one is the opposite for the other...
carving corners like a boss
Old 03-03-2013, 09:12 PM   #6
Well sence there is no dragstrip around here Im going to say I want a more track type set up. Bastards shut down KCIR about 6 months after I got my car
Old 03-04-2013, 05:56 AM   #7
Okay I really want to do the sport line one but I need to know if the front will work with 17x9 with 275/40r17.
Old 03-04-2013, 06:06 AM   #8
Silver Pony's Avatar
All day long. I've had the exact set up before.
Silver Pony is offline   Reply With Quote
Old 03-04-2013, 06:12 AM   #9
And there was no tire contact to the fender?
Old 03-04-2013, 07:11 AM   #10
No, I had 275/40/17 all the way around. It was on a 98 GT. I don't think that would make a difference. The only thing I didn't like was the front tire stuck out just a little too far from the fender. Made the back tires look skinny. I'd go wider in the back though, but other than that I never scrapped anywhere. Didn't matter what kind of incline I wet up or anything.
Old 03-04-2013, 08:08 AM   #11
Okay thanks for the info!
Old 03-04-2013, 08:28 AM   #12
jdavis96gt's Avatar
Region: West Virgina
Could go coilovers. Then adjust til u like it
Old 03-04-2013, 08:41 AM   #13
I would but thats a litte to much money for me right now. Does any one know wich kit is better for handling, the pro or sport kit?
Old 03-04-2013, 08:45 AM   #14
Mile high JDF's Avatar
The pro skit is a linear rate spring so it will have the same handling aspects all the way through a corner, the sport kit is progressive rate so it gets stiffer the more it compresses. For the best handling I would go with the pro kit. I haven't looked at the specs in a while pout the pro kit should be stiffer.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-10-2013, 03:18 PM   #15
GReese87's Avatar
MustangGt02 I don't know how set you are on the eibachs but check out the h&r super sports I just did them and personally I love them. They drop the front a little more then the back so you have that raked look which I am a fan of and they are progressive so they are actually very smooth for being a lowering spring.
GReese87 is offline   Reply With Quote
Old 03-11-2013, 07:23 PM   #16
I did look at them, I'm swayed to eibach cause of the kit that has shocks struts and sway bars.
Old 03-11-2013, 07:31 PM   #17
GReese87's Avatar
Yea I was looking into that kit but I ended up spending like 600 if I wanted the sway bars it woulda ran like 900 so it woulda only been like n extra 50 bucks. I just chose to spend the other 300 on a tuner ill get the sway bars later. Unless u track it the sway bars won't really make a huge difference so just depends on what you plan on doing.
02:43 AM
