Hood pins...INSTALLED - Mustang Evolution
Old 03-03-2013, 09:38 PM   #1
Tanker2012's Avatar
These FRPP hood pins are installed, finally. I chose to use the old hood bump rest holes to ensure symmetry and not have to drill new holes. The only problem with that is that it makes the pins too low for them to work correctly when the hood is lowered.
I had to use some grade 8 bolts to extend the pin distance and add some bolt couplers. Then, when the pin bolts were fully screwed down into the couplers, they were too long when the hood was lowered. I had to cut about 1/2" off of the FRPP pin bolts.
After about 3 hours of measuring, mock-ing stuff up, drilling and a trip to the hardware store, these things are installed. The kit came with two plates; one guide plate and one hood plate. I definitely recommend using the guide plate on the holes under the hood. All in all, they work great and look good (and many lessons learned).
What do you guys think?
ID:	93889   Click image for larger version
Tanker2012 is offline   Reply With Quote
Old 03-03-2013, 10:03 PM   #2
Venomouz831's Avatar
Nice same ones I used on my old mustang. I will tell you this though because if the elements mine got rusty and looked bad
)02 Gt, Founder of WE2G
Old 03-03-2013, 10:05 PM   #3
1lowGT's Avatar
Nice work.
Old 03-03-2013, 10:12 PM   #4
Tanker2012's Avatar
I used stainless for all hardware except for the grade 8 bolts I used to extend the pin bolts. Hopefully they won't rust or tarnish too quickly. My cars not a garage queen but I try to keep it clean and out of the snow/rain.
Old 03-03-2013, 10:27 PM   #5
Same here! From popping the hood often and the pressure the hood put up towards the pins it scratched up preety bad. But they look bad ***!
Old 03-03-2013, 10:28 PM   #6
The ones I had
Old 03-03-2013, 10:31 PM   #7
Tanker2012's Avatar
Yup, same as mine. Those look great. I really like the R hood. I really want one for my car (then I realize I have to do this and the hood lifts all over again lol). You didn't add the lanyards for the pins? I did...figured if I am going to buy and install the kit I might as well install all of it. Haha
Old 03-03-2013, 10:34 PM   #8
Yea they did. It's a keanen cowl hood and I did the work myself also but I didn't want the lanyards on lol. I actually still have those in my garage
Old 03-03-2013, 11:23 PM   #9
Kstangs2002's Avatar
Damn like how it looks real clean
Kstangs2002 is offline   Reply With Quote
Old 03-04-2013, 08:04 AM   #10
336badboy's Avatar
That's nice I want the flat ones
336badboy is offline   Reply With Quote
Old 03-04-2013, 08:07 AM   #11
It's not me, it's you.
primer2tone's Avatar
Awesome job!
03:52 AM
