2001 cobra vs 2003 mach1vs 2005 gt - Mustang Evolution
Old 03-04-2013, 07:22 PM   #1
Xavier9370's Avatar
Hey guys, I have been thinking of trading my car in because of lack of power. Which of this you think is the best choice.
Which if theese can I get more hp out if bolts on? Prons and cons
Xavier9370 is offline   Reply With Quote
Old 03-04-2013, 07:23 PM   #2
2003-2004 cobra terminator
Jcastro7608 is offline   Reply With Quote
Old 03-04-2013, 07:31 PM   #3
Xavier9370's Avatar
I can find a terminator here in central fl
Old 03-04-2013, 07:37 PM   #4
Butch's Avatar
Region: New Mexico
I'd go with the mach, better uhh tech¿ no development¿ yes that's the one, mach over 99/01 Cobras =[ sad I know but hey it is what it is,,,, plus the mach has better heads so no ticking, and better internals and slightly higher compression if I'm not mistaking
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 03-04-2013, 07:50 PM   #5
Xavier9370's Avatar
Yes I found out mach1 has 10.1.1 higher than cobra
Old 03-04-2013, 08:12 PM   #6
Rumplemenz's Avatar
i suppose im partial but i would say Mach 1. Ofcourse my first choice would be a termi but i understand thats not one of your choices
Rumplemenz is offline   Reply With Quote
Old 03-04-2013, 09:25 PM   #7
mcvicar04's Avatar
05-09 mustang gt are kinda the same boat as the 99-04 gts the power isn't there unless you go boost. The Mach 1 are great it's worth waiting for a good Mach or termi. You can boost all of them safely on stock motors.
mcvicar04 is offline   Reply With Quote
Old 03-05-2013, 12:12 AM   #8
Slow4V's Avatar
Mach 1 all the way
Better interior
Better suspension
Higher Compression
Forged crank
Straight axle
Brembo brakes
Shaker hood
.. All around bad ***
Old 03-05-2013, 01:05 AM   #9
Venomouz831's Avatar
I wonder what the 1/4 specs are for each one. Me and a local guy will be going head to head probably next month at the track. Mines a 99 with a few mods and his is a 04 mach with minor mods as well will post time slips
)02 Gt, Founder of WE2G
Old 03-05-2013, 01:30 AM   #10
DaBluedude's Avatar
The mach is a hell of a platform. And lots of room to grow. You can do a mean n/a build up to 380HP ish by doing the heads or a 6-10lb blower for 390-450 hp safely. Or go all out and build the lower end and go nuts! Decent stock 3.55 gearing and that shaker never gets old.
2003 Mach 1
Old 03-05-2013, 05:19 AM   #11
Xavier9370's Avatar
Great info thanks guys, I didt know thw mach1 had so many goodies.
What does the shaker does?
Old 03-05-2013, 05:50 AM   #12
WheelStander's Avatar
Here's your starting point comparison from CandD
ID:	94096   Click image for larger version
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 03-05-2013, 06:14 AM   #13
v8pony's Avatar
What app is that?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-05-2013, 06:25 AM   #14
Zero to 60
Old 03-05-2013, 10:41 AM   #15
Wow I thought it would've been closer
Old 03-05-2013, 10:45 AM   #16
Butch's Avatar
Region: New Mexico
Didn't think it was that huge of a jumo from auto to stick on the mach,,, driver mod on a snake is where its at
-----NEHP---
{Never Enough HP}
Old 03-05-2013, 10:53 AM   #17
DaBluedude's Avatar
Yeah I'm a little suspect about the quarter time listed for the mach. That's pretty quick for stock. Intake tune 275 summer rubber I'm running 13.5 with a 2.1 60' and power shifts. But im over 5400' so i guess maybe 13 flat at sea level with a tail wind maybe. I don't see the stock all season 245 rubber doing better off the line.
2003 Mach 1
Old 03-05-2013, 11:11 AM   #18
Slow4V's Avatar
I ran a 13.5 @107 I think 2.1 60 ft
Short shifter , Drag radials , X Pipe
But I need a driver mod Lol
Got new shocks and struts, and getting control arms , springs, and going back soon.
Old 03-05-2013, 11:12 AM   #19
It's true those numbers are good and right on the money.
There are two hidden variables here that are working together to achieve those numbers. Bear in mind these are numbers CD captured during the production year so there will be different test locations at different times of the year from year to year. In the past CD admits to changing out tires when necessary as an additional factor.
But the two variables working here are professional driver and rear factory gear ratio on the car that was tested, which is not listed.
Old 03-05-2013, 11:12 AM   #20
Slow4V's Avatar
Buddy of mine did 13.2 @107 with just short shifter, cold air , x pipe , and a badass driver mod
Old 03-05-2013, 11:20 AM   #21
There's bolt on New Edges Running 12.8 all over you tube.
One dude, he started out at 13.9 to start, then took like two years to do full bolt ons and ended up running 12.77 last fall.
Old 03-05-2013, 05:01 PM   #22
DaBluedude's Avatar
I don't doubt it. A steep set of gears and drag radials with a bit more power will go a long ways.
2003 Mach 1
Old 03-05-2013, 07:07 PM   #23
Slow4V's Avatar
Yeah right, over here 2V GTs are running 15s
Fully bolted GTs are running mid 13s
It depends on altitude and temp.
Old 03-05-2013, 09:12 PM   #24
Butch's Avatar
Region: New Mexico
Yep temp and altitude are your best friends worse enemies,,
-----NEHP---
{Never Enough HP}
Old 03-06-2013, 12:32 AM   #25
I didn't realize how much alt and temp affect youre 1/4 times until I was doing it and people were telling me about it. My best was 13.2 on my 02 gt
Old 03-06-2013, 01:45 AM   #26
Play nice.....
Old 03-06-2013, 02:10 AM   #27
Old 03-06-2013, 05:02 AM   #28
Lorraine's driver
ab_mach1's Avatar
Keep in mind that those numbers are with stock gears. The Mach's have 3.55 stock. What are the 99 Cobra's? That's probably why it showed as .7 slower than a manual Mach.
Instagram: @ab_mach1
Old 03-06-2013, 05:34 AM   #29
No kidding did you even read my post?
Old 03-06-2013, 07:13 AM   #30
Butch's Avatar
Region: New Mexico
Neither did I, a buddy told me how you can shave a second just by sea level I was like wwwwhhhhaaaatttt
---------- Post added at 07:13 AM ---------- Previous post was at 07:13 AM ----------
3.27s my good sir
-----NEHP---
{Never Enough HP}
Old 03-06-2013, 10:21 AM   #31
jjsg09's Avatar
The Mach 1 is what I would go with. The 05 GTs you can mod them and they get some good hp gains from a few mods. Also its a nice riding cruise car. Im more into just cruising than racing now I have a family so things change. Get the Mach its better to look at lol
Old 03-06-2013, 01:16 PM   #32
lee1rbc's Avatar
My Cobra ran 12.90s 1.99 60ft 109mph. 4.10s 285-35-18 nittos. d-spec shocks and springs. The big thing is the IRS. With the stock tires/suspension and 3.27 gears it was horrible off the line. If you tried to launch it had horrible wheel hop and if you rolled it out it lugged 2.20 60ft. Brace the IRS (front and rear mounts) install 4.10 and big tires and bam. Plus I love the IRS on the street, Honestly I feel like my Cobra can out handle any Mustang.
2001 SVT Cobra 04 Mach 1 motor & trans, 01 Cobra cams, bassani x, flowmaster catbck, JLT CAI, 4.11 gears, Tokico D-specs, eibach springs.
lee1rbc is offline   Reply With Quote
Old 03-06-2013, 01:18 PM   #33
Nice you got it in the 12's! I'm hoping I can get mine in the 12's. all I have is intake, exhaust, 285's and lowering springs.
Old 03-06-2013, 01:32 PM   #34
DaBluedude's Avatar
I'd like to get a few 12 time slips also but at 5400 (actually the track might be higher than that...) I'm thinking it's gonna need a power adder first. Intake tune exhaust 275 rubber and suspension set up for auto x won't get me there in my mach. Meh id rather carve corners anyways.
2003 Mach 1
Old 03-06-2013, 03:02 PM   #35
Xavier9370's Avatar
Ok so if I dicided to stay with my 04 gt and just putting all bolts on as possible (except supercharger, turbo, nitros ext.) What hp and 1/4 times could I expect?
04:41 PM
