Ecu - Mustang Evolution
Old 03-05-2013, 12:24 PM   #1
04_sonicblue's Avatar
Ecu
Should I put a 2000 cobra Ecu on my 04 gt ?
04_sonicblue is offline   Reply With Quote
Old 03-05-2013, 01:29 PM   #2
Region: Arkansas
I honestly don't think that it would benefit you any to do so. The computer in your car is set up for your car; whereas a cobra ECU is set up for a 4v with totally different compression ratios and everything else.
Sorry if that's wrong information, I'm a mechanical guy, not electronics.
BackPressure is offline   Reply With Quote
Old 03-05-2013, 02:08 PM   #3
No it's cool I was just curious I have no clue either lol
Old 03-05-2013, 03:46 PM   #4
Venomouz831's Avatar
Only cobra in 2000 was a cobra r
)02 Gt, Founder of WE2G
Old 03-05-2013, 03:55 PM   #5
I can get one for 75$, but was just a idea
Old 03-05-2013, 05:10 PM   #6
cliffyk's Avatar
No. At best it would accomplish nothing, in practice you would likely lose power..
Old 03-05-2013, 05:57 PM   #7
What kind do you suggest ?
---------- Post added at 06:57 PM ---------- Previous post was at 06:54 PM ----------
I just got this car a week ago and just starting to learn about them, but I've always wanted a mustang. And I may not need a Ecu cause it'll move I dead even with a gsxr 600, and beat a Colorado extreme (3.5) with a turbo on it
Old 03-05-2013, 07:05 PM   #8
Slow4V's Avatar
No
Old 03-06-2013, 12:34 AM   #9
cliffyk's Avatar
I think you do not understand that you do not replace the PCM (Powertrain Control Module, Ford's name for the ECU) in our cars when seeking more power*. The PCM contains a programmable memory chip, an EEPROM, that holds the tune; using appropriate hardware and software tools the stock tune is downloaded, modified as desired and reloaded (flashed) back into the PCM.
The PCM is not removed or replaced.
* - There are aftermarket ECUs for our cars, however they are not needed other than in the most radical builds, 600 rwHP+.
Old 03-06-2013, 07:20 AM   #10
Damn see, I never knew that
11:06 PM
