Squeak from front driver side - Mustang Evolution
Old 03-06-2013, 11:59 AM   #1
Rich04's Avatar
Every time i cut the wheel left or if i hit a bump i get a squeaking sound i greased up the steering column and everything i can on the left side it went away for a day or too now its back. Any ideas on what it can be?
Rich04 is offline   Reply With Quote
Old 03-06-2013, 12:02 PM   #2
1lowGT's Avatar
High pitch squeak? Metallic squeak?
Old 03-06-2013, 12:05 PM   #3
Rich04's Avatar
High pitched it sounds like something needs to be greased kind of squeak , even entering and exiting the car it happens and I'm not a big guy 5'10 160lb , do springs make sounds when they're bad?
Old 03-06-2013, 12:11 PM   #4
1lowGT's Avatar
the springs could, if they dont have isolators. are you lowered?
---------- Post added at 01:11 PM ---------- Previous post was at 01:10 PM ----------
But i doubt itd be the springs if it makes the noise when you get out. Try having someone push around on your car while you look and try to find out where its for sure coming from.
Old 03-06-2013, 12:23 PM   #5
Rich04's Avatar
Not lowered roads are to ****ty to lower my front. If i push down anywhere on my car it'll squeak on the front driver side i know its not the tire rod ending. Is it possible steering column or rack and pinion ?
Old 03-06-2013, 02:38 PM   #6
Warbot's Avatar
Mine has done that since i got the car on my right front even when i shift sometimes i think its the springs because when i lowered it, it seems to happen more frequently i just gave up haha sucks but it could be worse.
Warbot is offline   Reply With Quote
Old 03-06-2013, 02:40 PM   #7
Rich04's Avatar
Im not lowered so I'm really scratching my head on this one
Old 03-06-2013, 02:50 PM   #8
DaBluedude's Avatar
Could be the strut or steering rack. Or even just worn rack bushings. It's not likely to be a spring unless your isolaters are toast.
2003 Mach 1
Old 03-06-2013, 04:03 PM   #9
Rich04's Avatar
Yeah i guess i got my project for the weekend have tips on how to tell what it is?
Old 03-06-2013, 04:08 PM   #10
Rosco's Avatar
My stocks spring squeaked. I put my bbk springs in with stock iso and the squeaks went away.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 03-06-2013, 04:13 PM   #11
Rich04's Avatar
I do have a feeling its the springs , i cant lower my front to much due to some roads. Which springs would you recommend?
Old 03-06-2013, 05:27 PM   #12
Voltage258's Avatar
Region: Utah
I have Steeda sport springs and I think it only lowers it 1 1/4 inches all around I could wrong ... That is the smallest drop I have heard of.... I did not have a problem hitting or rubbing on anything except huge speed bumps, until I put my chin spoiler on... Now I rub on steep driveway entrances and stuff unless I go in at a huge angle.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 03-06-2013, 05:47 PM   #13
Rich04's Avatar
Where im at now if i come off speed bumps to hard my back will come down on them. My front just clears my garage and my drive way so i cant really even go low-_-
Old 03-06-2013, 06:02 PM   #14
onesickstang01's Avatar
Sway bar end links or sway bar bushings. Possibly ball joints. And lest likely A arm bushings.
onesickstang01 is offline   Reply With Quote
04:11 PM
