Oil leak - Mustang Evolution
Old 03-06-2013, 02:02 PM   #1
BigB227's Avatar
Oil leak
My stang has been leaking a bit oil for a while now and I need help on where it could possibly be coming from? It seems to be originating from the driver side from what I can tell . At first I thought it was my oil filter cause it had drops on it but it was tight as well as the others I've had before so I don't know
BigB227 is offline   Reply With Quote
Old 03-06-2013, 02:29 PM   #2
jjsg09's Avatar
Are you sure its motor oil? Because right next to the oil filter is the power steering pump and lines. Check that to see if the power steering isn't leaking too. Also could be coming from on top of the driver side valve cover where the breather tube it connected in the center.
Old 03-06-2013, 03:06 PM   #3
BigB227's Avatar
You know it might be dirty power steering fluid... Ill have to check. How do you change the fluid for that?
Old 03-28-2013, 03:56 PM   #4
GP3GT's Avatar
I'm having that exact problem right now!.. I took it to jiffy lube and they said it was my power steering pump and it's leaking on to everything else..
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
GP3GT is offline   Reply With Quote
05:37 PM
