lowering springs. - Mustang Evolution
Old 03-08-2013, 06:12 PM   #1
ryoung1219's Avatar
lowering springs.
im looking at lowering springs on am. whats the difference between b ford racing springs and c ford racing springs? or would yall recommend any of the other brands? idk what the difference is in any of them. all advice is appreciated.
ryoung1219 is offline   Reply With Quote
Old 03-08-2013, 06:28 PM   #2
StangerBanger04's Avatar
They honestly all do the same thing, lower your car obviously. It's mainly on your taste. Do you wanna be slammed or just low enough to where you can tell but not drag the ground lol. If you have enough money coilovers are always good cause you can adjust it to whatever you want. I personally have Eiback Pro-Kit and its lowered 1.5" all around and I think it's just about perfect. It's all your own preference. AM has a ton of lowering springs and pictures of how they look. Good place to look if you wanna see how they look. Gonna look awesome no matter what you get dude!
StangerBanger04 is offline   Reply With Quote
Old 03-08-2013, 06:29 PM   #3
ryoung1219's Avatar
oh ok. so whats the difference in the ford racing b and c though? just ride height?
Old 03-08-2013, 07:48 PM   #4
jdavis96gt's Avatar
Region: West Virgina
SR is good drop
Old 03-08-2013, 07:51 PM   #5
ryoung1219's Avatar
Originally Posted by jdavis96gt View Post
SR is good drop
Do they have a set for verts? I've been looking on am and I don't see the sr brand for a vert
Old 03-08-2013, 07:57 PM   #6
jdavis96gt's Avatar
Honestly I'm not sure. Prob just drop u a little more than 1.5", since Bert's have tougher rate. I think. Someone else will chime in.
Old 03-08-2013, 07:58 PM   #7
I'm not for sure on the Ford lowering springs but if I had to guess that's what I would say. Just like the Eibach Pro-Kit and the Eibach Sportline kit are the same type of springs just the sportlines make the car a little lower in the front.
Old 03-08-2013, 08:31 PM   #8
tonyd01gt's Avatar
Hi, the main difference on the ford racing springs are the spring rates.They will all lower your car. But some with give your car a lot stiffer ride from your stock springs.I believe the Ford cart is from B-G. The springs rates are : B,fronts(425/530)rear,(200/300). C,fronts (650) rear (200/300, F,fronts(460/570,rear(170/310), G,fronts(500/570,rear(170/310. B,C springs will give your car, front a .875-1 1/8 drop. .05-3/4 rear. F, front 1.2,rear 1.0, G front 1.2., rear 1.2
tonyd01gt is offline   Reply With Quote
Old 03-08-2013, 09:04 PM   #9
Lorraine's driver
ab_mach1's Avatar
You beat me to it tonyd
Attachment 94822
^From AM's site
Instagram: @ab_mach1
Old 03-08-2013, 09:07 PM   #10
Lorraine's driver
ab_mach1's Avatar
Also, I've hear the spring rates, like 425lb - 530lb means that they are a progressive rate spring.
*Edit* ^This is wrong. They mean 2-step linear. More info to follow...
Old 03-08-2013, 10:36 PM   #11
1shotkllz's Avatar
Don't mean to hijack a thread, but, spring rates, the higher the number the stiffer the spring? Just trying to learn since I'm in the market to be lowered.
1shotkllz is offline   Reply With Quote
Old 03-08-2013, 11:13 PM   #12
Mile high JDF's Avatar
Yes.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-08-2013, 11:42 PM   #13
Lorraine's driver
ab_mach1's Avatar
^This is wrong... When two rates are given, it is a 2 step linear spring. Each number represents one of the steps.
In a two-step linear spring, about half the coils have shorter spacing. As the spring compresses, the coils move closer. At a certain point, the shorter spaced coils touch, effectively eliminating them from the spring. You then have a spring comprised of only the longer coils. This "second-step" spring will be much stiffer than the whole spring (the more coils, the easier it is to compress the spring). The result is that you have one set of handling characteristics before the shorter coils touch and then you have another, completely different level of response after they touch. (HyperPro website)
I saw ^this at this site. Lowering Springs In General (there are two pages)
Old 03-12-2013, 02:57 AM   #14
02mineralgreygt's Avatar
I have the ford racing B springs and I'm enjoying the ride a lot better than the stocks. Smooth ride. Lowered but not too low for our horrid streets. Let me know if you have any questions about them.
02mineralgreygt is offline   Reply With Quote
Old 03-12-2013, 05:45 AM   #15
audioAl's Avatar
2012 w/ SR springs
SR is good drop
I did just the rears for now.
Name:	tn_Nurse Cindy 024.JPG
2014 DIB 3.7 "Blue Cyclone" on 275/40/18 RE 760 Sports/Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/J&M Bushings/ BMR cradle lockout/BMR CB006 brace/BMR cc bolts/S-04 pole position'
Old 03-12-2013, 07:54 AM   #16
Lorraine's driver
ab_mach1's Avatar
That's exactly why I will go with the Ford racing "C" springs. I want to lower it, but the roads suck pretty bad around here and I want to drive it, not just look at it. The C spring rates match up pretty close the the Mach 1 stock springs.
Old 03-12-2013, 08:00 AM   #17
Tomiboy0318's Avatar
U will really notice a big difference when you replace the fronts
Tomiboy0318 is offline   Reply With Quote
Old 03-12-2013, 11:52 AM   #18
Yea it was a very noticeable difference to me and others I know here too. It does it's job in getting rid of that 4x4 look literally. Before when when walking to the car I could see the shocks n all in that gap but now I would have to get level with the car to see them. I wish I took some better b4 n after picks for everyone on here but the first two are before pics n the last three are after.....wasn't the most extreme drop it was the drop I was looking for. Very happy with them. If you want stiffer ride with the same drop then go with the C springs. You've got options my friend.
ID:	95554   Click image for larger version
ID:	95556   Click image for larger version
Old 03-12-2013, 02:16 PM   #19
C springs are 600lb front 300lb rear, the B springs are softer not sure exactly how much but they are (both are linear spring rates vs progressive as far as I know)
C's are better for handling but worse for ride
Old 03-13-2013, 06:26 PM   #20
jjsg09's Avatar
I like my ford racing c springs very nice handling. Yes they are a bit stiff but not bad. I am going to be getting rid of mine, I want more drop so I bought h&r springs. So I hope it works out when I change them. But I don't have anything bad to say about my Ford racing c springs.
04:04 AM
