Spark plugs - Mustang Evolution
Old 03-09-2013, 02:50 AM   #1
Xaperez100's Avatar
Spark plugs
So my cousin got a 2003 gt the other day and it had misfires so we changed the spark plugs and boots and all that.. And it's miss firing still.. Anyone have any problems?
Xaperez100 is offline   Reply With Quote
Old 03-09-2013, 08:56 AM   #2
I had same prblem could be clogged air filter but mine was bad maf sensor or it could be coils hopefully not
Gilbert89213 is offline   Reply With Quote
Old 03-09-2013, 10:45 AM   #3
Xaperez100's Avatar
Damn.. Okay thanks!
Old 03-09-2013, 10:50 AM   #4
Eturner's Avatar
See if you can run a scanner on it. Could be a bad coil.
Old 03-09-2013, 10:52 AM   #5
Xaperez100's Avatar
We did at autozone they said its just missfiring but they said it was the fuel injectors?
Old 03-09-2013, 10:54 AM   #6
Rosco's Avatar
Check the spark plug gap. Make sure plugs and cop are installed correctly. You could have a dirty fuel filter or bad fuel injector causing it to be lean.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 03-09-2013, 11:05 AM   #7
If it said injectors u can buy pretty good ones off ebay that are like refurbished
Old 03-09-2013, 12:49 PM   #8
Xaperez100's Avatar
Do you know what they are supposed to be spaced at?
Old 03-09-2013, 12:59 PM   #9
Region: Arkansas
.052-.056 I believe.
The manufacturer recommendations should be on the fan shroud.
BackPressure is offline   Reply With Quote
Old 03-09-2013, 01:07 PM   #10
Xaperez100's Avatar
Oh okay thanks!
Old 03-09-2013, 04:00 PM   #11
Eturner's Avatar
Is it multiple cylinders that are misfiring?.. Or is it just one?..
Old 03-09-2013, 04:15 PM   #12
Xaperez100's Avatar
It feels like all lol. But I think autozone said 5th start up and something else. 4th feels horrible. It doesn't pick up at Ll
Old 03-09-2013, 04:37 PM   #13
Eturner's Avatar
If its multiple then it could be a bad fuel filter or fuel pump.
Old 03-09-2013, 04:41 PM   #14
Xaperez100's Avatar
Where's the fuel filter?
Old 03-09-2013, 06:57 PM   #15
Eturner's Avatar
Under your car, between the rear axle and fuel tank.
Old 03-09-2013, 08:12 PM   #16
Xaperez100's Avatar
Oh okay thanks!
Old 03-09-2013, 08:26 PM   #17
Eturner's Avatar
Oh okay thanks!
NP Bro. Hope you figure out what's going on with it.
Old 03-09-2013, 09:43 PM   #18
Xaperez100's Avatar
Thanks ill let you know how everything turns out!
Old 03-10-2013, 07:35 PM   #19
1996mustang's Avatar
Could be a leaking pressure regulator those can cause multiple misgire codes as well
Old 03-10-2013, 08:24 PM   #20
Xaperez100's Avatar
We figured it out.. I think lol because it isn't missing anymore but I think when my cousin put his side back in he didn't make sure the boot was put on the plug then put the cap and spring in at the same time to make sure the springs were touching the plug also so we redid them and everything's going good now
Old 03-10-2013, 09:29 PM   #21
Eturner's Avatar
Well then hopefully that's all it was. Lol. Sometimes we all overlook the simplest of things.
Old 03-10-2013, 09:30 PM   #22
Xaperez100's Avatar
Yeah it seems to be good and not missing and not taking forever to speed up lol
01:07 PM
