Low coolant light staying on - Mustang Evolution
Old 03-09-2013, 08:48 PM   #1
35th GT's Avatar
It's full of coolant, not running hot or doing anything abnormal. The light is just kind of annoying. Anyway of clearing this myself? The only weird thing is after I take a long trip say if the car has been driven for a hour straight when I get out I can hear the cap sizzling. But nothing is leaking and the coolant is staying full. This is a 99 GT
35th GT is offline   Reply With Quote
Old 03-09-2013, 08:59 PM   #2
deadsp0t's Avatar
Mine only comes on when the reservoir tank is low, the tank will be low and the radiator will be full on mine and the light will come on. I fill the tank above the cold line and the light goes off.. I don't know any other way to 'clear' the light.
That's unimpressive
Old 03-09-2013, 09:03 PM   #3
SilverPonyGT's Avatar
Mine does the same thing it comes on then goes away and after the car sits it turns off but coolant is always full
SilverPonyGT is offline   Reply With Quote
Old 03-09-2013, 09:05 PM   #4
35th GT's Avatar
Mine never goes off its constantly on though, it's annoying
Old 03-09-2013, 09:45 PM   #5
tonyd01gt's Avatar
Low coolant light stay on
The coolant sensor is bad in your reservoir.
tonyd01gt is offline   Reply With Quote
Old 03-09-2013, 10:07 PM   #6
35th GT's Avatar
I'll get it checked out thanks man
Old 03-09-2013, 10:13 PM   #7
tonyd01gt's Avatar
Look inside of the reservoir. You should be able to see the sensor. It probably is covered in some type of slim/rust. Causing your coolant light to stay on. Try clean it out. Maybe able to get enough out to get it working right. If not you will need another reservoir.
Old 03-09-2013, 10:32 PM   #8
BigB227's Avatar
Wired because when my intake manifold had a leak it would lea all my coolant and I never had a light come on
BigB227 is offline   Reply With Quote
Old 03-10-2013, 01:29 AM   #9
Venomouz831's Avatar
I have the same problem it's on and it's annoying
)02 Gt, Founder of WE2G
Old 03-10-2013, 03:07 AM   #10
bobsurvives's Avatar
lol mine has been stuck on forever too, too broke and lazy to buy another reservoir
bobsurvives is offline   Reply With Quote
Old 03-10-2013, 08:36 AM   #11
onesickstang01's Avatar
Usually the float gets gunked up and doesnt float anymore. Clean the reservoir up and actuate the float up and down with a screw driver. Its a two wire connector so you can jump the two wires to turn the light off
onesickstang01 is offline   Reply With Quote
Old 03-10-2013, 10:49 AM   #12
35th GT's Avatar
That was the problem I drained the tank and moved the float around with a screw driver and the light is now off.. Thank all of y'all for the help hopefully I won't run into anymore problems for a while
Old 03-10-2013, 03:09 PM   #13
35th GT's Avatar
The light came back on lol I guess the float is broke.. Looks like ill be buying a new over flow tank
09:14 AM
