Myth? - Mustang Evolution
Old 03-10-2013, 09:09 PM   #1
v8pony's Avatar
Myth?
Resting hand on the shifter bad for the trans?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-10-2013, 09:10 PM   #2
Region: Arkansas
Ehhh...depends how you "rest" it.
Pressure on it isn't good in any circumstance.
It's not comfortable anyways. Just don't do it.
BackPressure is offline   Reply With Quote
Old 03-10-2013, 09:12 PM   #3
1slosix's Avatar
I never had any shifter issues from it...and it was my hands best friend lol
carving corners like a boss
Old 03-10-2013, 09:16 PM   #4
Ubnbit's Avatar
Every car I've ever had was a stick. If that is true, id be in bad shape. I dnt think pullin on it or doing more than resting on it is a good idea but I have a ford racing shifter in my Shelby, that's where my hand is if I'm in the car.
Old 03-10-2013, 09:16 PM   #5
Region: Arkansas
I really think it's an old-school issue that people still believe.
Way back when, cars didn't have shift-stops. Out modern trannies to so that you don't overshift and jam the gears together and I'm betting that they help with pressure on the shifter.
Like ubnbit said, as long as you are just resting on it, you should be okay.
I still don't do it just out of habit from driving my old Muncie Rock Crusher tranny.
Old 03-10-2013, 09:17 PM   #6
My hands always on the shifter, I guess the only way something MIGHT happen is if you are tugging on it while its in gear
Old 03-10-2013, 11:09 PM   #7
maldog's Avatar
Region: Nevada
The reason you should not do this is because the weight of your hand, and arm, is multiplied due to leverage. This can move the shifter rail slightly off the detent ball which holds the shift and fork in its proper position. The shifter fork fingers are then being rubbed against the rotating synchronizer sleeve (think of placing your thumb and forefinger inside the grooves of a small pulley).
Over time the shift fork fingers and the sleeve will wear down. Once the gap is excessive the force applied to the gearset in question (1/2, 3/4, etc) will try to slide the synchronizer inserts inside the sleeve. There is a point of no-return here and the synchronizer hub/sleeve assembly will then try to place itself in the neutral position; a.k.a jumping out of gear.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 03-10-2013, 11:32 PM   #8
Venomouz831's Avatar
Hmm interesting
)02 Gt, Founder of WE2G
Old 03-11-2013, 08:55 AM   #9
cliffyk's Avatar
My grandfather taught me to not do that many years ago because it does apply an unnecessary load to the shift forks and synchronisation rings as maldog said. This could be a lesser problem with modern transmissions, however after 55 years of not resting my hand on the shift lever I have no plans to change now...
Old 03-11-2013, 09:04 AM   #10
not for how the shifter attaches on a mustang, you cant put any more pressure on the trans by putting your hand on the shifter~
It probably came alone with column shifters where if you rested you would actually pull the shifter downard and push it up into the gear it was in vs shifters that sit on the console.
Old 03-11-2013, 11:39 AM   #11
Rich04's Avatar
I sometimes have my hand on the shifter, i never heard of this before now. Its 4th gear I'm resting my hand, Guess i should stop that!
Rich04 is offline   Reply With Quote
Old 03-11-2013, 04:00 PM   #12
1shotkllz's Avatar
I fail to see how resting your hand on the shifter will harm the trans. Unless your hand weighs well over 10 pounds, I think it'll be alright.
1shotkllz is offline   Reply With Quote
Old 03-11-2013, 04:11 PM   #13
MineralGrayGT's Avatar
Region: Wyoming
I agree.
MineralGrayGT is offline   Reply With Quote
Old 03-11-2013, 04:13 PM   #14
Slow4V's Avatar
Yes , bad for syncros
03:55 AM
