A/C delete - Mustang Evolution
Old 03-11-2013, 09:58 AM   #1
1lowGT's Avatar
A/C delete
Is it worth $56 on ford racing?
Old 03-11-2013, 10:43 AM   #2
Lorraine's driver
ab_mach1's Avatar
For less weight and free up a little HP, probably. But only if you know you won't want A/C. It sucks in the summer where I'm at. Lol You'd definitely want to do a complete removal of A/C related parts to get the full benefit. That pulley replaces the compressor, so you'll want to remove the hoses, receiver/drier/accumulator, and the condenser coil. You could probably leave the evaporator since its in the dash and would not be worth the effort to get to.
Instagram: @ab_mach1
Old 03-11-2013, 10:47 AM   #3
Lorraine's driver
ab_mach1's Avatar
You might want to checkout the How To on American Muscle. Might give you a better idea of what it takes and help you decide if it's worth it.
http://1.cdn.lib.americanmuscle.com/files/24090.pdf
Old 03-11-2013, 10:55 AM   #4
Slow4V's Avatar
I did it and live in Texas ,
Of course it's going to be hot
Take off belt
Remove Compressor ( 3 bolts )
Plug hoses ( Prevent Damage to HVAC Damage )
And there you go
It comes with hardware in kit
Old 03-11-2013, 10:59 AM   #5
Lorraine's driver
ab_mach1's Avatar
Take off belt
And there you go
Is it still worth it though if you don't remove the remaining engine compartment parts? That would be quite a bit of additional weight loss missed if not removed.
Old 03-11-2013, 11:28 AM   #6
Slow4V's Avatar
Well I did the delete because compressor went out and had it for a while ( no money ) and then
Did my whole HVAC system .. Everything
And that was a pain, and honestly accumulator , hoses don't weigh very much.. All the weight is the compressor. But you can still take off lines and stuff.. Makes engine bay look cleaner
Old 03-11-2013, 12:05 PM   #7
1lowGT's Avatar
You got a picture of before & after?
07:27 AM
