Mbrp exhaust - Mustang Evolution
Old 03-11-2013, 05:09 PM   #1
MustangMonk's Avatar
Mbrp exhaust
Anyone know if the MBRP mufflers for the 09 GT work with the stock muffler hangers or will I have to buy new ones for them??
Sincerely
Hung Up
MustangMonk is offline   Reply With Quote
Old 03-11-2013, 05:20 PM   #2
The MBRP axle backs come with their own hangars and are designed to be a direct replacement. You will not need anything extra for the installation. Installation is easy, using a socket you undo the clamp behind your factory mufflers and pull the stock axle back out of the rubber gromits. To install the new axle back just reverse the process. You should be able to do it yourself if youve ever fixed anything on a car or even changed your own oil before, its simple and will actually take less time than changing your oil.
DieselStang is offline   Reply With Quote
Old 03-11-2013, 06:12 PM   #3
Tried yesterday....could not remove mufflers unless the hanger came off...and there was a bolt between the muffler and body of the car...couldn't get a tool on it...too tight!
Old 03-11-2013, 07:06 PM   #4
So you broke the hanger off the stock exhuast or just wernt able to remove it? Once the clamps that mate the axleback and pipes that go over your rear axle are removed or losened you should have some wiggle in your axleback. The wire hangars on the axleback are attached to rubber gromets. At this point the muffler/axleback wire hangers should wiggle and pull free from the rubber gromits without unbolting anything else.
Old 03-11-2013, 07:40 PM   #5
Thanks! Going back under it Wednesday, let you know how it went!!
Old 03-13-2013, 11:11 AM   #6
Got them on this morning!!! Sounds great!!! Couldn't be happier!!!!
Old 03-13-2013, 01:43 PM   #7
Good job!! Sometimes all it takes is going back and taking a second look and having a little patience and persistance.
Old 03-13-2013, 03:49 PM   #8
I had to remove the hangers tho.. Had the right tool today..that made a big difference! Thanks for the help!!!
Old 03-13-2013, 03:51 PM   #9
Special tool huh? I wonder if your mufflers were hung different than my old 06GT's
Old 03-13-2013, 04:47 PM   #10
Not really special...but I needed a ratcheting wrench...there was a bolt between the top of the muffler and the body that wouldn't allow me to wiggle the muffler off. All I had the first day was sockets..and even the short one wouldn't fit with the clearance I had!
Old 03-13-2013, 04:49 PM   #11
Oh bummer. Well at least you got it.
exhaust
06:26 PM
