Question about HID's - Mustang Evolution
Old 03-11-2013, 05:55 PM   #1
Tiffsobelle's Avatar
So I bought the Bi Xenon kit, and am not happy with it honestly. I don't like how it runs off just the driver side and the passenger side doesn't look as bright.
Here's the question, it had an HID kit on it when I bought it (not Bi Xenon), BUT the high beams were yellow. THAT is what I want to get away from, and the reason I bought the Bi Xenon.
Is there any way to get away from that yellow high beam with the HID? Since it's a single bulb (with a small bulb for the high beam beside it), I can't change that high beam bulb (it's part of the HID bulb).
I know nothing really about the HID's, so hopefully y'all can give me some insight.
Thanks!
Tiffsobelle is offline   Reply With Quote
Old 03-11-2013, 06:24 PM   #2
Doe_Rae_mi's Avatar
Thanks!
I have the same product and both mine are not yellow
Old 03-11-2013, 06:30 PM   #3
So you have the normal HIDs and the high beams aren't yellow?
What level are you running? Maybe that's the problem with the ones that was on it when I bought it (I don't know what they are).
Old 03-11-2013, 07:41 PM   #4
Doe_Rae_mi's Avatar
I'm 6000k but that shouldn't effect anything
Old 03-12-2013, 01:33 AM   #5
02mineralgreygt's Avatar
Thanks!
To be honest I've never seen a set up like that. I have a set of ddmtuning bi-xenon hids. (No yellow highs like you). But I can honestly say I am still not satisfied because the light output is really only focused slap dead in the middle. Very narrow with no lighting off to the side to see the curb n wat not. I've had good luck with these kits but now I am soon to retrofit my lights using these morimotos mini h1 bi-xenon projectors. The light output difference from the pics I've found look amazing compared to stock. Plus it doesn't have that look of the other aftermaket projectors. That's something I would consider doing but if you want to ride it out with a kit do your thing. Look into it you may like.
Ddmtuning.com for the bi-xenon hid kit.
Theretrofitsource.com to take a look at the projectors n other info you might like.
Good luck
02mineralgreygt is offline   Reply With Quote
10:25 AM
