Next Mod? - Mustang Evolution
Old 03-13-2013, 12:10 PM   #1
Slp_loudmouth's Avatar
Next Mod?
Should I buy a tuner or a new drive shaft?
Slp_loudmouth is offline   Reply With Quote
Old 03-13-2013, 12:14 PM   #2
Cantlin01's Avatar
What do you have done to your car?
Cantlin01 is offline   Reply With Quote
Old 03-13-2013, 12:18 PM   #3
Slp cat back. O/r x. 3.73 gears. Bbk 78 throttle jlt cai. Have pulleys on the way short throw The rest is all cosmetics
Old 03-13-2013, 12:21 PM   #4
Tuner and lightweight drive shaft are worth about the same performance to a stock car and both will improve your gas milage. I would say either are a good way to go. However if you have any engine mods go for the tuner, the tuner will magnify your current mods. If this is your cars first mod go for the driveshaft, it will give you the same performance level and save your engine a little longer until you start to modify it.
DieselStang is offline   Reply With Quote
Old 03-13-2013, 12:21 PM   #5
Adogg's Avatar
You should get a tuner for sure you will see better gains from the mods you have now
Don't hate....... appreciate
Old 03-13-2013, 12:21 PM   #6
Cantlin01's Avatar
Def a tuner then so you can get the hp out of your mods
Old 03-13-2013, 12:22 PM   #7
SCT/BAMA tuner. With those mods youll notice a huge difference in performance.
Old 03-13-2013, 12:22 PM   #8
Cantlin01's Avatar
+1
Old 03-13-2013, 12:23 PM   #9
Good job on the JLT/BBK combo and picking out the 373s for your manual car. What brand pulleys did you go with?
Old 03-13-2013, 12:28 PM   #10
Steeda. And thanks my gfs dad has a 05 s/c gt and her brother has a 99 cobra so that's all we do is work on them but I'm gonna order the tuner next Friday
Old 03-13-2013, 12:32 PM   #11
Good parts selection. Your setting yourself up for better power numbers than most get. If you ever need advice on mods and brand selection I can tell you whats what so your mods continue to give you the best power numbers possible.
Old 03-13-2013, 12:34 PM   #12
Thanks man
Old 03-13-2013, 01:44 PM   #13
1lowGT's Avatar
Tuner
Old 03-14-2013, 03:22 PM   #14
Tomiboy0318's Avatar
Go with the tuner
Tomiboy0318 is offline   Reply With Quote
Old 03-14-2013, 03:54 PM   #15
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I don't know if your running around with stock suspension, but I would upgrade your springs to some H&R's or something comparable. But if you're set on a tuner vs driveshaft, I would go tuner. My experience with tuners is you get used to the power increase real quick.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-14-2013, 08:49 PM   #16
I got suspension done just named the bolt ons
06:04 PM
