Shift press - Mustang Evolution
Old 03-13-2013, 01:12 PM   #1
BigB227's Avatar
Shift press
What does this option on an SCT X3 tuner do?? It is set at 0% and can in both negative and positive directions. It can be set by shift press 1-2 , shift press 2-3 and shift press 3-4
BigB227 is offline   Reply With Quote
Old 03-13-2013, 01:27 PM   #2
I beleave your refering to the shift presure feature for automatic cars. The SCT tuner can harden or soften shifts on an automatic stang and is one of the largest performance benifits for a tuner on an auto stang.
DieselStang is offline   Reply With Quote
Old 03-13-2013, 02:02 PM   #3
BigB227's Avatar
Ok I have an automatic stang, and I set the shift press to 25% and It seemed to me like the firmness in my shift went away totally. I set it back to 0% and the firmness came back
Old 03-13-2013, 02:06 PM   #4
Will the tuner allow you to go negative % ? If so, try that.
Old 03-13-2013, 02:18 PM   #5
BigB227's Avatar
Yes it does ill try that and see how it works
Old 03-13-2013, 02:49 PM   #6
I guess it worked.. Your probly still out beating your stang enjoying the hard shifts, tires cherping and lurching you forward everytime you shift at full throttle and wishing you had 20 gears to go through.. lol
Old 03-13-2013, 03:13 PM   #7
BigB227's Avatar
I havnt gotten time to do it yet ill update when I do
Old 03-13-2013, 03:15 PM   #8
Oh alright. Have fun!
Old 03-13-2013, 03:26 PM   #9
Venomouz831's Avatar
Won't it put stress on the tranny
)02 Gt, Founder of WE2G
Old 03-13-2013, 03:30 PM   #10
Yes it will add some stress but the trans can take it. The added pressure is not enough to even blink at when you compair it to adding 25 hp. So in short the abuse is to a minimal.
Dont worry your trans will not randomly up and die on you because of it.
Old 03-13-2013, 04:03 PM   #11
Continues beating then is what you should be weary of.
Old 03-13-2013, 04:49 PM   #12
Be weary of wether or not it can take the so called "beating" and it can take it, so no worries..
Old 03-13-2013, 04:49 PM   #13
BigB227's Avatar
Setting it to negative seemed to make the firmness go completely away so ill just keep it at 0
Old 03-13-2013, 04:54 PM   #14
I would talk to who ever you bought your tuner from about that one, you should be able to make your shifts harder.
Old 03-13-2013, 05:34 PM   #15
BigB227's Avatar
I bought it from AM and Bama tuned it, I guess I should cal them up
Old 03-13-2013, 07:01 PM   #16
Yes I would do that and see what help they can offer.
05:00 PM
