Pressure plate worn - Mustang Evolution
Old 03-14-2013, 11:10 AM   #1
cleanmach1's Avatar
Pressure plate worn
So i took my car into a local shop about a a rattle coming from my clutch pedal and they tell me my pressure plate is worn and i need a new clutch. Problem is i just replaced the clutch about 10k miles ago. So my question is can failure to properly install a clutch correctly lead to premature wear on the pressure plate
cleanmach1 is offline   Reply With Quote
Old 03-14-2013, 12:08 PM   #2
cliffyk's Avatar
If that is exactly what they told you I would find another shop. That the pressure plate is worn in 10k miles so as to need replacement is very unlikely; and that they could determine that without pulling the transmission is damned near impossible.
Are your sure they didn't say/mean "clutch disc"?
Old 03-14-2013, 12:12 PM   #3
cleanmach1's Avatar
No they said pressure plate. And it's not the same shop who replaced the clutch 10k miles ago. So your saying to know the exact problem they need to drop the tranny completely to find out?
Old 03-14-2013, 12:31 PM   #4
cliffyk's Avatar
Unless it has self-destructed (is is a Spec clutch?) I cannot imagine how they were able to pinpoint a defective pressure plate by peeking in through the inspection port...
Old 03-14-2013, 12:40 PM   #5
Blogger
99ford's Avatar
I would go back to the same place who installed the clutch, and see if they are willing to work with you.
Old 03-14-2013, 12:55 PM   #6
cleanmach1's Avatar
I also want to add that the car drives fine for now, theres been no slipage just grinding noises and ticking from the pedal when slowing down while in gear
Old 03-14-2013, 01:53 PM   #7
Tomiboy0318's Avatar
I would still have it checked by the shop that put it in you might have a warranty. I know my shop offers a 12 month 12k warr on All the work we do.
Tomiboy0318 is offline   Reply With Quote
08:45 AM
