help me plz - Mustang Evolution
Old 03-15-2013, 11:39 AM   #1
help me plz
Ok the car I bought I think some one put tramission booster fluid in the brake fluid it causes my brakes to lock up what can I can I jusr flush the brake fluid or will I have to replace master and all that plz help me find the cheapest solution
Gilbert89213 is offline   Reply With Quote
Old 03-15-2013, 11:45 AM   #2
sprdave's Avatar
I'm pretty sure you just need to bleed each brake line one at a time and
keep replacing new brake fluid in your brake resoiver at the same time.
You might try to bleed a little fluid out and see if it helps.
You might have just a little to much brake pressure in the system.
When i have done new brakes I had to release some brake fluid.
I had to much pressure and it wouldn't allow the breaks to move
or release enough.
sprdave is offline   Reply With Quote
Old 03-15-2013, 11:52 AM   #3
Thanks bud but I just called him and he did like an idiot do I think still just bleeding them will help
Old 03-25-2013, 10:56 AM   #4
When bleeding the brakes you need to bleed shortest brake line to longest. Bleed in order. First, driver front. Second, passenger front. Third, driver rear. Fourth passenger rear. If the brakes dont stop locking up you can try replacing the ABS module but if it comes to that I would take it to a shop and tell them what happened.
DieselStang is offline   Reply With Quote
Old 03-25-2013, 11:30 AM   #5
Venomouz831's Avatar
I thought you bleed the brakes starting from the farthest one
)02 Gt, Founder of WE2G
Old 03-25-2013, 11:36 AM   #6
T-TEN trained me to do closest first when I was getting ASE certified for brake systems.
Old 03-25-2013, 11:44 AM   #7
You made me second guess myself but yes you start shortest. Starting with the shortest ensures any air/fluid in the system is pushed out completely. The system has the most presure in the shortest line. If you start long and go short the stronger line can force air/fluid back into the longer lines.
Old 03-25-2013, 12:08 PM   #8
Oh ok gotcha, thanks for clarifying.
10:24 PM
