2002 Mustang FT leaking fuel - Mustang Evolution
Old 03-15-2013, 11:45 PM   #1
Had my fuel pump replaced but now when I drive it and turn right it leaks gas.
usmcwendy is offline   Reply With Quote
Old 03-15-2013, 11:46 PM   #2
blackhawk 1's Avatar
gotta get that fixed before you have @ car fire
blackhawk 1 is offline   Reply With Quote
Old 03-16-2013, 06:18 AM   #3
Ckennedy121's Avatar
Turn right or left? Because if its left then its more than likely your filler neck gasket.
Pop your head under your gas tank and follow the filler neck to the gas tank, if you see a black gasket that is torn up or completely free from the gas tank, that's your leak. It's a very easy fix if you have a buddy to help you out!
Ckennedy121 is offline   Reply With Quote
2002 mustang
05:18 AM
