Turn rear rotors - Mustang Evolution
Old 03-16-2013, 10:51 AM   #1
01mineralgreyv8's Avatar
Turn rear rotors
Where can I get my rear rotors resurfaced and how much will it cost?
01mineralgreyv8 is offline   Reply With Quote
Old 03-16-2013, 10:58 AM   #2
98GTCONV's Avatar
Any shop that does brakes. Rear rotors are cheap. You could probably pick up 2 new ones for under $60.
98GTCONV is offline   Reply With Quote
Old 03-16-2013, 12:30 PM   #3
Yeah I can get the rotors for $28.99 a piece I just wanted to see if it was cheaper to just get them resurfaced
Old 03-17-2013, 03:33 AM   #4
2002VertGT's Avatar
I can get raybestos rear ceramic rotors for 16.26...
4.10 Gear/RPM thread
Old 03-17-2013, 08:49 AM   #5
CodyNelson's Avatar
Region: West Virgina
I'm a manager at my local Autozone and I never recommend having rotors turned! The metal becomes thin and will warp the moment your brake hard on them. And in some cases shops remove too much material and I've seen several rotors get hot, become brittle and shatter. A shop will charge you $20+ per rotor to turn them and for just a tad more you can get a nice brand new set
Old 03-17-2013, 09:45 AM   #6
Where at?
---------- Post added at 11:45 AM ---------- Previous post was at 11:43 AM ----------
Thanks for the info! I'll def be picking up some new rotors instead of resurfacing the old ones, don't want any warping problems
Old 03-17-2013, 10:51 AM   #7
CodyNelson's Avatar
No problem! Also be sure to get a rotor that will work with well with your selected pads. For example, ceramic pads should be used with rotors created for ceramic pads due to the ceramic being much more aggressive. If you use a ceramic pad on a normal rotor it will wear your new rotor out 3x faster
Old 03-17-2013, 11:36 AM   #8
2002VertGT's Avatar
Where at?
I get mine at a local guy on the DL....but even Rock auto has some decent prices.
I'm getting the fronts for just a few penny's more....
Raybestos front and rear ceramic rotors, front and rear ceramic pads, moog inner tie rod, and a new break caliper for rear drivers side for $100
06:37 AM
