Missing in my car - Mustang Evolution
Old 03-17-2013, 09:36 PM   #1
marleenoel's Avatar
Missing in my car
I have a miss in the mustang I just bought. We are thinking its just a coil but not exactly sure.. Anyone have any suggestions? It's a V8 so do all the coils need redone or could it be just one of them??
marleenoel is offline   Reply With Quote
Old 03-17-2013, 11:14 PM   #2
MACh237's Avatar
Send a message via MSN to MACh237 Send a message via Skype™ to MACh237
Hey Welcome to the forums
Can you be specific please? what kind of miss? when it happen?
- 2004 Ford Mustang V6 (Summer Ride)
- 2000 Volkswagen Jetta (Winter Beater)
- 2011 Hyundai Accent (Last Resort)
- 2012 Aldo Beel Leather Shoes (Daily Ride)
MACh237 is offline   Reply With Quote
Old 03-18-2013, 05:11 AM   #3
goodwinta1's Avatar
If it is throwing a check engine code, start there. If it is just one cylinder causing the problem the code should point you in the right direction. If you don't have the ability to pull it yourself just stop by a local parts store and they should be able to pull it for you.
goodwinta1 is offline   Reply With Quote
Old 03-18-2013, 08:51 AM   #4
stampde's Avatar
If you don't have a code scanner or access to one ...
cheap way out but a little time consuming is to pull 1 plug wire off at a time and see if anything changes , say you pull #1 off and you have another miss , that's not the bad cylinder , then move to the next and so on , till eventually you pull 1 off and it doesn't change , then you've found the culprit , replace the plug and the coil , you only need to do the one
2011 GT Auto
Old 03-18-2013, 01:50 PM   #5
marleenoel's Avatar
Thank you Everyone... we will try and see what happens!! we cant believe that its not throwing a code at us!
Old 03-18-2013, 01:59 PM   #6
1lowGT's Avatar
Bad miss at idle? I currently have a horrible miss going to the shop tomorrow.
Old 03-18-2013, 01:59 PM   #7
1lowGT's Avatar
+1
Old 03-18-2013, 05:28 PM   #8
GReese87's Avatar
A miss without a code could be a vaccum problem it may not be a full miss just running rough at idle. Check vaccum lines they could cause a rough idle which could be mistaken as a miss.
GReese87 is offline   Reply With Quote
Old 03-18-2013, 06:47 PM   #9
marleenoel's Avatar
Attachment 96793
no it does not miss while its at idle.... just when I am driving
09:34 AM
