MM coilovers - Mustang Evolution
Old 03-19-2013, 10:37 AM   #1
RUNNWLD's Avatar
Region: Utah
MM coilovers
I am wanting I get some coilovers soon so I can slam it. They say with the kit it uses koni struts but I went to the struts and there are two different koni struts which ones to I need to get?cause the one of the sets are way cheaper. The koni str.t struts and shocks or the koni singe adjustable?
RUNNWLD is offline   Reply With Quote
Old 03-19-2013, 04:37 PM   #2
RUNNWLD's Avatar
Region: Utah
So I'm guessing no one knows but what do you guys think of the race land coilovers?
Old 03-19-2013, 04:41 PM   #3
Mile high JDF's Avatar
I've heard of the MM kit, not that other brand. I would personally go with the more expensive Koni if I was going with that exact one. Are you looking for just looks or handling?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-19-2013, 04:52 PM   #4
RUNNWLD's Avatar
Region: Utah
Just looks so I wouldn't think I need all the expensive stuff you know?
Old 03-19-2013, 05:08 PM   #5
Haha coilovers are expensive by themselves. I would double check with MM about which Konis to use, I don't see there being a difference but you never know. If there isn't a difference then I see no reason to buy the expensive ones if you're just going for looks.
Old 03-19-2013, 05:31 PM   #6
Ewokjax95's Avatar
If you're looking to just slam the car and have no intentions of tracking the car, get Racelands. Be warned though, replacements will probably be in order after a few years.
Ewokjax95 is offline   Reply With Quote
Old 03-19-2013, 06:44 PM   #7
RUNNWLD's Avatar
Region: Utah
Okay sweet so do you know anything about race lands?
Old 03-21-2013, 03:56 PM   #8
RUNNWLD's Avatar
Region: Utah
I just found out that the racelands will not work with caster camber plates so how would I get my car aligned if I had it lowered 2.5 in?
Old 03-21-2013, 03:57 PM   #9
You buy the MM coilovers and do it right.
Old 03-21-2013, 04:18 PM   #10
RUNNWLD's Avatar
Region: Utah
Haha alright so I guess I'll just have to do the fronts than later do the backs sense it's not all in one kit besides for like 1200 dollars.
Old 03-21-2013, 04:28 PM   #11
The kit does come with CC plates though.
Old 03-21-2013, 04:42 PM   #12
RUNNWLD's Avatar
Region: Utah
Yes it does I just want something that's a cheaper coilover kit cause I only want looks I dont track my car or anything so I don't need all this expensive stuff.
Old 03-21-2013, 04:54 PM   #13
RUNNWLD's Avatar
Region: Utah
Old 03-21-2013, 06:04 PM   #14
Understandable. But it isn't exactly the best idea to go cheap on a vital component like suspension. I've got a buddy with a cheap set of coilovers on his Integra and every time he brings his car into the shop we have to tighten up the locking plate on them because it loosened itself up. Whereas my buddy with a $1500 kit on his Evo hasn't had any of those problems at all.
Old 03-21-2013, 06:11 PM   #15
RUNNWLD's Avatar
Region: Utah
Yeah I get ya!
Old 05-17-2013, 02:11 PM   #16
RUNNWLD's Avatar
Region: Utah
If I went coilovers up front with the mm coilovers what all do I need just for the front? What struts I don't have a lot of money and I just want to go low I don't drag or autocross keep in mind.
Old 05-17-2013, 02:26 PM   #17
Venomouz831's Avatar
I think you need a pair of konis
)02 Gt, Founder of WE2G
Old 05-17-2013, 04:50 PM   #18
Region: Arkansas
STR.Ts are just Koni yellow sport struts set to 0° stiffness with no adjustability.
STR.Ts are awesome for a non-track use or infrequently tracked car.
Dad has them on his 07 with Steeda Ultralites. It rides as smooth as butter.
BackPressure is offline   Reply With Quote
Old 05-17-2013, 09:13 PM   #19
RUNNWLD's Avatar
Region: Utah
So those koni shocks an struts will work with the mm coilovers cause I don't wanna get some that won't fit the coilovers?
Old 05-17-2013, 09:18 PM   #20
Region: Arkansas
Coilovers are a strut and spring in one, are they not? I don't think you need both
Old 05-17-2013, 10:13 PM   #21
If you just want to lower it get a set of springs/shocks and call it a day, you don't need coilovers. I mean the MM stuff is the best short of a SLA setup but there are other options for coilovers too that don't cost as much like UPR if you don't care about handling although it WILL handle better than stock.
Old 05-17-2013, 10:38 PM   #22
RUNNWLD's Avatar
Region: Utah
I have h&r super sport but I want coilovers for the front to slam it but I hear the hot are noisy!!
Old 05-17-2013, 10:57 PM   #23
RUNNWLD's Avatar
Region: Utah
Upr are noisy
Old 05-18-2013, 09:45 AM   #24
RUNNWLD's Avatar
Region: Utah
:Bump:
03:44 PM
