uneven ride hight... - Mustang Evolution
Old 03-19-2013, 09:40 PM   #1
Voltage258's Avatar
Region: Utah
So I have been noticing that the drivers side of my car sits lower than the passenger side by I would guess 1/2 to 1 inch. I have not measured it yet I will tomorrow.. What causes this springs, shocks? Could the previous owner put the 2 front springs on one side and the 2 rear springs on the other accidentally? It's been this way for as long as I can remember but I have been noticing it a lot more these days. Let me know what you think and what my options are. Thanks.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 03-19-2013, 09:48 PM   #2
NewMtang's Avatar
Too many SUPERSIZED meals from Mickey Dees...
Old 03-19-2013, 09:51 PM   #3
Voltage258's Avatar
Region: Utah
Haha very possible.
Old 03-19-2013, 10:07 PM   #4
zinc_yellow's Avatar
Region: New Mexico
The previous owner was a lonely oversized man
zinc_yellow is offline   Reply With Quote
Old 03-19-2013, 10:23 PM   #5
Voltage258's Avatar
Region: Utah
For the record the previous owner was a old guy that barley drove the car. And the guy before him I do not know. But seeing as it only had 38,000 miles on it, when I bought it last year. I do not think that is enough sitting time.. Unless he slept in the car as well.
Old 03-20-2013, 06:10 AM   #6
tonyd01gt's Avatar
Hi, check to see if the spring isolators where left off of the passenger side. They will give your car about a 1/2 inch drop also.
tonyd01gt is offline   Reply With Quote
Old 03-20-2013, 11:25 AM   #7
1996mustang's Avatar
Check your struts a stuck strut would cause that to happen or bad strut
Old 03-20-2013, 12:07 PM   #8
1lowGT's Avatar
Could be that the springs have settled in like that, could try taking isolators out on the other side. After that struts.
Old 03-20-2013, 12:30 PM   #9
Mile high JDF's Avatar
Well if the front springs are on the drivers side then that might be the problem and you might just be noticing it more. I would say swap them and see if that fixes things. As springs get old they tend to sag, but that's usually at 150K+ miles and a lot of years of wear and tear.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-20-2013, 12:55 PM   #10
Voltage258's Avatar
Region: Utah
I will try to check everything when I get home.. How hard is it time pull springs off and get them back in?
Old 03-20-2013, 01:00 PM   #11
It can be done with basic hand tools. Took me about 4 hours the first time mostly be cause I was trying to be cautious and I was wasting time trying to use a spring compressor.
Old 03-20-2013, 02:25 PM   #12
1lowGT's Avatar
3 hours if you know what you're doing
Old 03-20-2013, 03:09 PM   #13
Voltage258's Avatar
Region: Utah
Alright thanks guys I will screw with it this weekend. And since I don't know what I'm doing I'm going to give myself 6 hours.. I have put a lift kit on a jeep so I'm hoping it's similar.
Old 03-20-2013, 03:29 PM   #14
Doe_Rae_mi's Avatar
It could be that ur just on a hill. Mine looks different all the time because of the way it's parked and other things
Old 03-20-2013, 03:49 PM   #15
Voltage258's Avatar
Region: Utah
That's what I thought at first but looking at it on 2 pretty flat surfaces you can see one side is higher. I will try to take a picture when I get home.
Old 03-20-2013, 06:30 PM   #16
Voltage258's Avatar
Region: Utah
Well I think you were right actually.... I measured it then moved it to the center of the garage and measured it again and it was still off a little but not by much.... So I think I'm just paranoid and a tard.. Sorry for the false alarm guys...
Old 03-20-2013, 06:32 PM   #17
Doe_Rae_mi's Avatar
Lol same here. OCD when it comes to the stang
04:45 PM
