What oil do you use? - Mustang Evolution
Old 03-20-2013, 07:56 PM   #1
escottcarp's Avatar
I bought my '02 GT in January and need to change the oil this weekend. I've search threads looking to see what oil the 99-04 owners use and cant find a thread. So, any recommendations on conventional of synthetic or a blend? Also, viscosity? Thanks.
escottcarp is offline   Reply With Quote
Old 03-20-2013, 08:02 PM   #2
Voltage258's Avatar
Region: Utah
I use Mobil 1 full synthetic 5w-20. Kind of depends on what you like. A lot of people use royal purple I have noticed but I don't think it's going to make a huge difference what brand you use. Just try and use full synthetic. I'm sure a ton more people will chime in as well.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 03-20-2013, 08:33 PM   #3
Slow4V's Avatar
I use 5w30 Mobil 1 Synthetic
Old 03-20-2013, 08:35 PM   #4
Eturner's Avatar
5w30 Royal Purple.
Old 03-20-2013, 08:35 PM   #5
Rejekt's Avatar
I run Mobil 1 full synthetic 10w30 here... always have.
Rejekt is offline   Reply With Quote
Old 03-20-2013, 08:39 PM   #6
i was running mobil 1 5-20 before i tore the engine down and built it back now i run royal purple 5-20 never had any issues with noise or ticks or anything
nightmare04gt is offline   Reply With Quote
Old 03-20-2013, 08:41 PM   #7
95v686gt's Avatar
I run 5w-30 valvoline in my v6 and VR-1 5w-30 will be in my DOHC swap car. Was going to go royal purple but I can get the vr stuff cheaper
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-20-2013, 09:30 PM   #8
Billymich's Avatar
Valvoline doesn't actually sell synthetic oil, they use a loophole to market it that way though and you'd never know from the prices!
Old 03-20-2013, 10:47 PM   #9
Region: Arkansas
Good to know! Thank you.
I always use Mobil 1 full synthetic 5W-20 when I can afford it, otherwise I just use Motorcraft 5W-20.
Definitely use Motorcraft filters though; do NOT use Fram. SVTPerformance did a filter test and the Fram was one of, if not, the worst performer. I don't recall exactly, sorry.
BackPressure is offline   Reply With Quote
Old 03-21-2013, 05:38 AM   #10
escottcarp's Avatar
I have always used havoline 10W-40, just like my dad did. I live in Mississippi where the summers are pretty hot. Is there any problem with a 5W-20 in the summer heat? I think it's interesting that the oil filler cap states 5W-20.
Old 03-21-2013, 09:22 AM   #11
Mzilla's Avatar
Valvoline does not make a VR-1 Dino or synthetic 5w-30 only a 10w-30. I used the 10w-30 regular VR-1 for 1000 miles for break in on my new teksid block. The VR-1 is great for break in due to high zinc content. You are not suppose to use the VR-1 if you have catalytic converters because it will clog them. I would highly recommend using using Royal Purple HPS 5w-30. I put this in after break in and it was amazing how much smoother the engine is. The RP HPS is also recommended for cars with no cats due to its high zinc and phosphorus content. It's really awesome stuff. I figured when I have over 15k in my engine alone good oil is only insurance.
Mzilla is offline   Reply With Quote
Old 03-21-2013, 09:32 AM   #12
Mustang936's Avatar
I always just put in motor craft, I can't remember which one but they changed recommendations to 5w-20 or 5w-30
Mustang936 is offline   Reply With Quote
Old 03-21-2013, 09:41 AM   #13
Venomouz831's Avatar
Royal purple here with a knn
)02 Gt, Founder of WE2G
Old 03-21-2013, 09:46 AM   #14
99mustang99's Avatar
Royal purple in all the fluids in my car
99mustang99 is offline   Reply With Quote
Old 03-21-2013, 11:47 AM   #15
the reason for the thinner oil is because after 2000 ford built their engines with some tighter tolerances and thicker oil sometimes has some problems making its way through the journals and such in the engine. im in cali atm and its gets around 115 or so and i still run the 5-20 synthetic with k&n without any issues
Old 03-21-2013, 12:01 PM   #16
v8pony's Avatar
Reasoning for that is the fram doesnt have the anti-drain back valve, which is needed for our engines..any filter that has that valve will do the job but I agree I always stick to motorcraft, they are MADE for our cars
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-21-2013, 01:55 PM   #17
Billymich's Avatar
NAPA has really good filters too, I forget who makes them
Old 03-21-2013, 02:00 PM   #18
+ 1 Same here.
delff128 is offline   Reply With Quote
Old 03-21-2013, 03:50 PM   #19
Originally Posted by delff128 View Post
+ 1 Same here.
10+$ for 1 quart of oil sucks but its good for the engine and I rather preserve the engine and treat it right than have to go back a replace my forged internals
Old 04-01-2013, 09:37 AM   #20
gladiatoro's Avatar
I always use penzoil platinum ( full synthetic ) in all my vehicles I used to use mobil 1 but it does not say FULL SYNTHETIC on the bottle like penzoil platinum does not sure why , perhaps it is not full synthetic after all , penzoil is good , I also use a filter that is designed for synthetic oils ( K&N).
gladiatoro is offline   Reply With Quote
Old 04-01-2013, 10:22 AM   #21
Same on the air filter here too
Old 04-01-2013, 03:29 PM   #22
I'm all about Royal Purple fully synthetic 5w30 with Royal purple oil filter. I've also heard nothing but good things about Mobil 1 fully synthetic.
jazzystang is offline   Reply With Quote
Old 04-01-2013, 04:09 PM   #23
gladiatoro's Avatar
So you are saying that mobile 1 is full synthetic then ok.. wasn't sure on that even though it says synthetic no where on the bottle could I find the words FULL SYNTHETIC like it says on penzoil platinum .
Old 04-01-2013, 04:24 PM   #24
That's what I've heard. I don't use Mobile 1 cause I like the purple stuff. Double check on the Mobil 1 as I may have heard incorrect information.
Old 04-01-2013, 05:01 PM   #25
I love my royal purple too lol
Old 04-01-2013, 05:35 PM   #26
CodyNelson's Avatar
Region: West Virgina
Mobil 1 is a full synthetic oil. That and royal purple tested the highest with the API (American Petroleum Institute). After 10,000 miles of abuse they both were retested and both had higher ratings than alot of other oils tested new. In the test Royal Purple was the best by a bit but Mobil1 was second by a bit of a landslide. Castrol Edge was third, Valvoline SynPower was fourth and Pennzoil Platinum was fifth.
Old 04-01-2013, 07:51 PM   #27
gladiatoro's Avatar
Thanks for the info , I think I'm switching to Mobil 1 for my next oil change .
Penzoil Platinum got in fifth not so good .
Old 04-01-2013, 08:51 PM   #28
CodyNelson's Avatar
Yeah and they are just about the same price and the Mobil1 goes on sale every 3 or 4 months at your local Autozone. $33.99 and comes with a Mobil1 filter
Old 04-01-2013, 08:55 PM   #29
2300turboford's Avatar
Whatever synthetic is the cheapest at the time lol
Old 04-02-2013, 10:48 AM   #30
1lowGT's Avatar
What weight of royal purple? And what filter number?
Old 04-02-2013, 10:52 AM   #31
CodyNelson's Avatar
5w30 for the oil and the Royal Purple filter part number is #20-820
Old 04-02-2013, 01:01 PM   #32
Go with 5w20 or 5w30. I strongly suggest 5w30 if u have 50K or more miles.
Old 04-02-2013, 01:07 PM   #33
1lowGT's Avatar
Thanks man
Old 04-02-2013, 02:07 PM   #34
CodyNelson's Avatar
Anytime
10:01 AM
