Power steering delete and ac delete - Mustang Evolution
Old 03-21-2013, 01:33 AM   #1
Speed_Mister's Avatar
Region: Arkansas
I've deleted my ac lines from the pulley, ac compressor now I need to delete the condenser and pulley. And I haven't started deleting my power steering so I'd like to know how for sure to do so and ways to rig my belt with out my engine overheating. Do I keep the power steering pulley? I'm sure I could figure it out but like someone with experience guide me before I start taking thinks out and breaking stuff my cars for drag racing so I'm not keeping it in there just extra weight..
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 03-21-2013, 08:04 AM   #2
1996mustang's Avatar
Im subscribing to find out how one would achieve this. I looked at my belt and saw that if u remove p/s and a/c all you have is alt w/p and crank plus tension pulley and idler. I dont see how you could unless u delete w/p as well make it electric and just have the belt from crank to alt. But then the concern would be to not break alty. Im deff interested to know
Old 03-21-2013, 10:50 AM   #3
Region: Arkansas
You got a diagram of the pulleys?
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 12:14 PM   #4
Region: Arkansas
So ik under my good just got done taking out the ac condenser now I'm looking at bypassing my ac pulley keep one of the idle pulleys and keep the power steering as a idler cause I'm not sure how I could run with just three pulleys without over heating. I don't want a electric water pump yet.
---------- Post added at 12:14 PM ---------- Previous post was at 12:11 PM ----------
And how hard would it be to turn without power steering?
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 09:54 PM   #5
Quite hard actually lol our cars or atleast my years are heavy. But good thing is once its moving turning is easy but going slow turns or trying to park would suck. Try turning the wheel without the car on in neutral and imagine that everyday ill guarantee youll get ripped with muscles lol
Old 03-21-2013, 09:59 PM   #6
Region: Arkansas
Here's what I got I could get the power steering because it is connected to the brake system too
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:01 PM   #7
Region: Arkansas
I got every a/c part removed now just need to get my power steering out.
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:06 PM   #8
Different from my year my tensioner points down so you could do that. And im sure it wont overheat due to if imo u have a shorter belt i would assume the water pump would spin faster pumping coolant at a more higher rate than before atleast that is how i take it
---------- Post added at 11:06 PM ---------- Previous post was at 11:03 PM ----------
What year is yours? Maybe if you could use the smaller of the 2 sn95 year w/p pulley u might get a belt combo routing. However the problem is all 3 necessary pulley sit one above the other
Old 03-21-2013, 10:13 PM   #9
Region: Arkansas
2003 but I got Underdrive pulleys
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:29 PM   #10
I was thinkin u could run crank alt w/p and tensioner.....from the crank around the pump to alty to tensioner and back to crank. Might work or could use like a dead pulley to help with eouting of belt
Old 03-21-2013, 10:34 PM   #11
Region: Arkansas
I'm wanting to get rid of the power steering so bad but not sure how to take it out.
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:36 PM   #12
if you take out the p/s pump, you will pretty much loose the hydrobooster, i would suggest before you do you try and get a manual rack for steering as well as manual brakes before you take down a vital pump like that.
Old 03-21-2013, 10:39 PM   #13
Region: Arkansas
Where can I find a manual rack and manual brakes?
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:49 PM   #14
94-04 Mustang Manual Brake Kit Fender Line
manual brake kit
---------- Post added at 11:46 PM ---------- Previous post was at 11:45 PM ----------
Flaming River 1994-2004 Ford Mustang Manual Rack and Pinion FR1892 - UPR Products
manual rack and pinion
---------- Post added at 11:49 PM ---------- Previous post was at 11:46 PM ----------
imo i believe this one i would go with since i know the brand strange and their axles as well
http://www.uprproducts.com/mustang-m...ke-kit-94.html
Old 03-21-2013, 10:52 PM   #15
Region: Arkansas
Wonder if I could get some from an older mustang with manual brakes and steering.
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 10:58 PM   #16
possible i wouldnt say its not, however not sure how it would work since you would still need an adapter plate if the old boosters were vacuum booster instead of hydrobooster like our sn95s. something to deffinitely look into
Old 03-21-2013, 11:00 PM   #17
1996v6stang's Avatar
Im sure manual steering isnt as bad in these cars as it is my dads old 69 coronet... That think weighs like 4k+ one of ours stripped for drag racing should weigh like 3k right?
1996v6stang is offline   Reply With Quote
Old 03-21-2013, 11:02 PM   #18
Region: Arkansas
I hate how our year model mustang are so heavy my goal is to make my mustang weight 2500lbs
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 11:02 PM   #19
Thats pretty ****in light! Damn man good luck!
Old 03-21-2013, 11:04 PM   #20
Region: Arkansas
Lol ok maybe not that light but I want it light as balls
Full Bolt Ons
370rwhp 470rwtq
Old 03-21-2013, 11:42 PM   #21
well 30 pounds from p/s plus whatever else weight removed from hydrobooster, and maybe rear seat deletes so i would say atleast you lose around 150 lbs, which aint bad at all, considering how heavy our cars are.
Old 03-21-2013, 11:46 PM   #22
Region: Arkansas
Ptsh I've gutted my whole interior and put it back in like 7 times but never done it at the track I am the next weekend though.
---------- Post added at 11:45 PM ---------- Previous post was at 11:43 PM ----------
Lol ill take everything out and leave driver seat and dash, I want lexan windows one day too cause glass weights alot.
Hopefully I'll pop a bigger wheelie too 😃
Full Bolt Ons
370rwhp 470rwtq
Old 03-22-2013, 12:47 AM   #23
Hopefully I'll pop a bigger wheelie too dde03
Haha yeah man! Love that wheelie! Pics bro! Even better! A video!
Old 03-22-2013, 01:00 PM   #24
Region: Arkansas
I got three pictures of 3 different wheelies but no videos my mom has a nice Nikon canon camera that can shoot videos I'm gonna get here to shot one and ill post it on here.
Here's three wheelies we caught on picture.
Full Bolt Ons
370rwhp 470rwtq
Old 03-22-2013, 02:17 PM   #25
Ewokjax95's Avatar
Holy tractor style!! Those back wheels are insane! I see how you pull tires up. You must be just dead hooking. What size are they?
Ewokjax95 is offline   Reply With Quote
Old 03-22-2013, 02:21 PM   #26
Region: Arkansas
28X10.5-11.5 and I started pulling my wheels up after I removed my ac compressor and lines, relocated battery, and removed from bumper support.
Full Bolt Ons
370rwhp 470rwtq
Old 03-22-2013, 03:14 PM   #27
Lmfao at this guy, just made my day bro.
07:22 PM
