car keeps cutting off - Mustang Evolution
Old 03-21-2013, 06:15 AM   #1
taf9991's Avatar
i have a 02 gt and just recently it has been shutting of on me. when it shuts off the gauges sweep all the way then come back and my battery light and my check engine light come on it starts right back up with no problem afterwards but just yesterday i got in and i noticed my theft light was blinking fast and then it wold stay on so i cut the car off and turned it back on and it went off. this morning it was blinking again so i cut the car off and turned it back on and it shut off with the same sweep and lights on has anyone else had this problem or know what it could be. im thinking an electrical problem somewhere just wasnt sure
taf9991 is offline   Reply With Quote
Old 03-21-2013, 10:57 AM   #2
My 96 mustang did some thing like that when i Replace the heater core one of the plugs was lose under the dash u can try making sure nothing's lose and everything's has a Good connection
derrickk is offline   Reply With Quote
Old 03-21-2013, 12:30 PM   #3
i agree could be an eletrical issue but also it might be an issue with the anti theft system if it sends a code your car would start but shut right back down. see if you can get a scanner on it and see if any codes are being pulled
nightmare04gt is offline   Reply With Quote
Old 03-21-2013, 12:51 PM   #4
I didn't even think about the Antitheft System can try using a Spare key I have heard cases of people dropping and cracking the keys And messing the chips up in the keys
Old 03-21-2013, 01:55 PM   #5
Mustang936's Avatar
My theft light is always blinking, and ive heard of this just being a thing with mustangs on the stock tune. Id suggest getting those codes read by a scan tool. Hope you get it fixed
Mustang936 is offline   Reply With Quote
Old 03-21-2013, 03:44 PM   #6
taf9991's Avatar
thanks yall i work at pepboys so when i pulled it in the shop i was looking under the hood and it turned out that the PO somehow smashed the negative battery terminal and it was loose enough to pull off the terminal so i just replaced the terminal and let the computer reboot itself and works perfectly now
Old 03-21-2013, 04:26 PM   #7
I was just about to suggest ground glad you got it figured out.
Old 03-22-2013, 12:04 AM   #8
good to hear you got it fix. glad it was something simple
02:35 AM
