Another debate - Mustang Evolution
Old 03-21-2013, 10:56 PM   #1
Slp_loudmouth's Avatar
So I'm saving for something a little bigger just don't know what. I'm stuck between stage 3 cams or a shaker hood I know cams are obvious choice but don't know which step to take first. Any other mod ideas are welcome nothing over 1500
Slp_loudmouth is offline   Reply With Quote
Old 03-21-2013, 10:56 PM   #2
Region: Arkansas
What are your goals?
BackPressure is offline   Reply With Quote
Old 03-21-2013, 10:57 PM   #3
Well right now just modding the ***** until I have enough for a terminator or older gt500
Old 03-21-2013, 11:08 PM   #4
Region: Arkansas
Simple solution in that case.
Don't. Save your money.
Old 03-21-2013, 11:11 PM   #5
That's the fun part I'm putting half towards the car because I wanted to keep this as my daily
Old 03-21-2013, 11:13 PM   #6
Region: Arkansas
Ah! I see!
I highly recommend gears (preferably 4.10s) and a tuner first thing.
Cams will probably end up being more than $1,500. Parts alone for stage 3 wil run you almost $1,000 and installation is $750 at least.
Old 03-21-2013, 11:17 PM   #7
Ah! I see!
Have them already and the comp cams stage 3 are 620 no valve springs needed
Old 03-21-2013, 11:25 PM   #8
Region: Arkansas
I guarantee you will need new beehive springs and cam gears. Where'd you find the stage 3s?
I have never heard of 2v stage 3 cams from Comp Cams.
Old 03-21-2013, 11:28 PM   #9
+100
Old 03-21-2013, 11:36 PM   #10
Go on there site they say all you need is higher gears which I have
Old 03-22-2013, 12:06 AM   #11
Region: Arkansas
I'm guessing you're talking about the XE278AH or XE274H
XE278AH manufacturer requirements: SOHC-Street/strip, needs 3.73+ gears, 2400+ stall. Intake, exhaust, computer & valve spring upgrade. Rough idle.
XE274H mfr requirements: SOHC-Hot street cam, 3.55-3.73 gears, 2000+ stall, computer upgrade recommended. Rough idle. HOWEVER, under the recommended/related items right below the specs, they list beehive springs. There's a reason for that. Furthermore, looking at the valve and lobe lifts - 0.5 and 0.274 respectively - that's pretty aggressive, but since the valve lift is in fact .500, you technically don't need new springs. Again, HOWEVER, if you don't replace them and something goes wrong, Comp won't cover any damages.
You'll tend to need to run stiffer springs when you have a cam with a more aggressive lobe profile (very aggressive lobe profiles that essentially launch the valve open over the nose of the cam lobe), and you need that spring to bring the valve back to the seat. The Comp Xtreme grinds are pretty aggressive, but the good thing is OHC grinds have faster ramp rates to begin with due to the low friction design. It's not as drastic as a flat tappet or roller engine going to one of Comp's Xtreme Energy grinds anyway.
In other words, you don't NEED new ones since OHC designs are a bit easier on the valves, but it's definitely recommended to make sure everything will run safely and cover your *** in case something breaks.
Old 03-22-2013, 09:16 AM   #12
Got ya and yeah the 274h is what I was looking at
Old 03-22-2013, 09:25 AM   #13
Think of it this way, spend the extra money on the springs and gears or you might have to replace your whole engine... Is it worth it?
Old 03-22-2013, 09:43 AM   #14
yea putting money into a car will get you nothing back out, so you are hurting yourself if you are trying to save up for another car, just enjoy, save and when you can buy what you want.
Thats what I did for my 03 cobra
07:02 PM
