Help!!?!?? - Mustang Evolution
Old 03-22-2013, 07:49 PM   #1
Fordhartbreaker's Avatar
Help!!?!??
New plugs wires batter idle air controle cold air car idles great put in drive it volts dive and car dies need help please car was fine before upgrades
Fordhartbreaker is offline   Reply With Quote
Old 03-23-2013, 08:51 AM   #2
I'm thinking it may be a vacum line but why would that make my volts drop? Car starts fine every time? Any help would be appreciated. Thanks in advance
---------- Post added at 08:51 AM ---------- Previous post was at 08:49 AM ----------
Or it could also be that the idle air control I just put on is a bad one??? Or maybe something to do with the batter being undone the computer is off wack and needs to relearn settings????? How do u reset computer just unplug batter right??
Old 03-23-2013, 09:02 AM   #3
99mustang99's Avatar
Unplug battery at terminal for 5 to 10 secs and when started there should be a gate sweep of the gauges meaning computer has been reset
99mustang99 is offline   Reply With Quote
Old 03-23-2013, 09:05 AM   #4
tonyd01gt's Avatar
Help!!?
To reset just unbolt the battery post. keep off 5-10 minutes.On the drop in charge. Do you have UDP on the car? Check all your grounds for the volt drop.
tonyd01gt is offline   Reply With Quote
Old 03-23-2013, 09:54 AM   #5
No I do not have udp when I hooked the batter u last time I didn't get a gate sweep?? It was undone for ab 30 mins to an hour
Old 03-23-2013, 10:24 AM   #6
I know in 99-04 if the battery is disconnected for 5-10 there should be a gate sweep( needles sweep from lowest to high point like 0-150mph ) when battery is reconnected and car is turned on, it should on your car if I'm not mistaken
Old 03-23-2013, 10:27 AM   #7
I know what ur talking ab my 2002 would gate sweep my 96 won't but from what I have said does it sound like vacume or electrical?
Old 03-23-2013, 10:31 AM   #8
Could be vacuum leak I honestly would call a good mechanic shop and just explain the problem, they'll have more of a direct answer than most of us, unless someone else has had this problem on here
Old 03-23-2013, 10:35 AM   #9
Ok will do my guess is that the new idle air control is bad so when u put it in gear it puts a load on the engine... Not being able to have the vacum to support that would bog the engine down also making the alt turn slower bc of the low rpm making the volts drop ... I also think it's vacum bc when u hit the breaks the motor will bog down to breaks use vacum so.... Idk just an idea I could be way off ha just kinda want to get it back on the road soon I have missed her all winter
Old 03-23-2013, 10:40 AM   #10
Yeah ik vacuum leaks/problems can bog down a car, never had issues with idle air control but a good mechanic that is not just gonna make you buy parts to get him money but actually fix the problem at hand would be your best bet, just get it fixed and done correct and have all summer to lay down some rubber lol
Old 03-23-2013, 03:51 PM   #11
Thanks for the help everyone all I had to do is drive it over 30 and the computer reset to where it should she's running like a top pulls alot harder to Monday she gets udp and sct tuner
Old 03-23-2013, 03:55 PM   #12
Np man
10:22 PM
