Changing plugs - Mustang Evolution
Old 03-23-2013, 02:22 PM   #1
marleenoel's Avatar
Changing plugs
How many torque specs do u use when putting in new plugs on a 2001 gt? Just wanna make sure they don't over torqued..
marleenoel is offline   Reply With Quote
Old 03-23-2013, 02:26 PM   #2
1slosix's Avatar
snug them down and barely past that
carving corners like a boss
Old 03-23-2013, 02:28 PM   #3
marleenoel's Avatar
We are thinking 13. Trying to look it up
Old 03-23-2013, 02:30 PM   #4
Spark plugs don't really need a specific torque, just make them snug then just a little past.
Old 03-23-2013, 03:24 PM   #5
Region: Arkansas
That's what I do. Finger tight then toque it 1/4 more.
BackPressure is offline   Reply With Quote
Old 03-24-2013, 03:30 PM   #6
v8pony's Avatar
Anyone know of a detailed write-up or how-to on changing these plugs?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-24-2013, 03:36 PM   #7
1slosix's Avatar
long extension and wobble socket
Old 03-24-2013, 04:22 PM   #8
98vertgt's Avatar
+1
98vertgt is offline   Reply With Quote
Old 03-25-2013, 03:21 PM   #9
cliffyk's Avatar
NO...
The shop manual spec is 11 lb-ft. Finger tight then 1/16th turn will be about 13-15 lb-ft, most plug maker's recommendation for taper seat plugs. Adding 1/4 turn will bring them up to 45 lb-ft or better--way too tight...
Here is a test I did using a "plug bore" machined into a block of aluminum alloy:
You can see that adding 1/6th turn (22.5°) required 15 lb-ft, 1/4 turn (90°) more took 47 lb-ft!
It is vital to properly torque the plugs on the 4.6L 2V, not doing so is what leads to the plug blowouts we hear about far too often.
I personally feel 11 lb-ft is too low for used heads with oily/carboned-up threads--and with the common use of never-seize (not recommended by Ford, the minimal threading was engineered to deal with seizing issues). These both lubricate the threads and make the plug easier to "back-out" under normal operation.
This is why I use and recommend 13 to 15 lb-ft, generally setting my wrench for 170 lb-in (14.2 lb-ft); though for a year or more now I have been using a torque-limiting socket:
This neat tool is calibrated to very accurately provide 20 N·m (177 lb-in, 14.75 lb-ft) of torque, no more and no less. Read more about it here.
09:45 PM
