P1130 and P1132 - Mustang Evolution
Old 03-24-2013, 07:50 PM   #1
98GTCONV's Avatar
P1130 and P1132
Threw these codes today. What is the most common problem when these codes come up?
98GTCONV is offline   Reply With Quote
Old 03-25-2013, 03:07 PM   #2
cliffyk's Avatar
Here you go--work the list, top to bottom.
On a '98 I would first check the fuel pressure at the rail, a bad fuel pressure regulator could cause the engine to run rich...
Old 03-26-2013, 03:28 PM   #3
98GTCONV's Avatar
My local mechanic took a look at it today. His best guess was a dirty injector. So I put some injector cleaner in the tank to see if it helps.
Old 03-27-2013, 01:40 PM   #4
98GTCONV's Avatar
Well I cleared my code after I put the injector cleaner in. CEL stayed off for a while, then came back on. Now when im at a stoplight or just idling, rpms go from 700rpm to 1000rpm. It shutters and vibrates a lot. Doesn't sound like it wants to cut off, and now its just throwing P1132. What should I try next?
10:54 PM
