Egr - Mustang Evolution
Old 03-25-2013, 06:44 PM   #1
1lowGT's Avatar
Egr
Okay. So I have a misfire still at idle and the mechanic said that it may have a leaking egr valve. So my question is, is there a way to tell if it is leaking?, could it be a leaky gasket? Or should I just get the whole egr valve for $64?
Old 03-25-2013, 08:05 PM   #2
Billymich's Avatar
if you have an egr leak its usually pretty easy to tell, you can see/hear it.
Old 03-25-2013, 08:26 PM   #3
1lowGT's Avatar
What's it sound like. And his can you see it.
Old 03-25-2013, 08:41 PM   #4
1slosix's Avatar
pop it off and look for a crimp in the gasket
carving corners like a boss
Old 03-25-2013, 08:46 PM   #5
1lowGT's Avatar
I'll try that. Hopefully it warms up so I can do this. Mechanic said a leaky egr or bad injector on 2
Old 03-25-2013, 08:51 PM   #6
1slosix's Avatar
i don't see an EGR really causing a misfire unless it's completely clogged but you'd be throwing a code for EGR flow insufficient in most cases
Old 03-25-2013, 08:53 PM   #7
Billymich's Avatar
If its leaking, you'll hear/feel pulses of exhaust around it, usually you'll see water spray out
Old 03-25-2013, 08:54 PM   #8
1lowGT's Avatar
I'm not sure what codes I'm throwing besides not having cats but I guess I'll ask him and the check it out.
---------- Post added at 09:54 PM ---------- Previous post was at 09:53 PM ----------
Then I don't think that's my problem. I'll still check it out before buying anything lol
03:35 PM
