Idling problems 97 Gt - Mustang Evolution
Old 03-26-2013, 06:27 PM   #1
channingjames's Avatar
It idles at 600 rpms. There's a little sputter here and there. When I first start the car it stays at 2000 rpms and comes down slow. Also I think that there is a vacuum leak but I can't find it. I've sprayed the whole engine with carb cleaner. I recently replaced: EGR valve, ICT, AIC, fuel filter, spark plugs. I cleaned my throttle body and air filter, MAF sensor, ACT sensor. I don't know what the problem could be or if idling at 600rpm is normal. All help and comments appreciated!
channingjames is offline   Reply With Quote
Old 03-26-2013, 08:38 PM   #2
Billymich's Avatar
Sounds like you're throwing parts at the problem. If you had a vacuum leak it would idle high, not low. Can you HEAR a vacuum leak? What is your timing set at? Did you reset your base idle?
Old 03-26-2013, 09:37 PM   #3
I thought 600 was idling high? And they were all parts that needed to be changed anyways. I don't know what my timing is set at or how to reset my base idle
---------- Post added at 10:35 PM ---------- Previous post was at 10:34 PM ----------
And yes I can hear a vacuum leak. It sounds like its coming from the very back of the engine. I think I can hear it from inside the car.
---------- Post added at 10:37 PM ---------- Previous post was at 10:35 PM ----------
Also if I'm just parked and I rev it up a little, like to 1 or 2 it will drop to about 300 or so and sometimes almost die, then come back at 6. And sometimes it goes back and forth from 600 to 700 simultaneously
Old 03-27-2013, 10:31 AM   #4
Billymich's Avatar
Sounds kinda like a vacuum leak, grab a section of tubing and put it in your ear, move it around the bay till you hear it. YOU WILL NOTICE, when i found mine it literally pulled itself onto the leak and created a 'vacuum' in my ear.
Check your pcv valve
Old 03-27-2013, 11:19 AM   #5
I will try that and my Pcv valve is fine
Old 03-28-2013, 12:07 PM   #6
Duke4165's Avatar
Mine idles around 1k for a couple minutes then drops to 600 but sometimes if I am waiting to get out my school parking lot ill be sitting there with my foot on the brake and my engine just revs itself between 400-1000 it just goes up and down for like 30 seconds then says at 600
Duke4165 is offline   Reply With Quote
02:30 PM
