does ported typhoon intakes help hp more than an ford racing pi - Mustang Evolution
Old 03-27-2013, 10:44 AM   #1
Xavier9370's Avatar
Someone is offerings me a typhoon ported intake, are those better than ford racing pi intake in hp ?
Xavier9370 is offline   Reply With Quote
Old 03-27-2013, 10:49 AM   #2
Billymich's Avatar
Depends on the porting job, and your cam. You'll probably get more HP but less low end torque.
Old 03-27-2013, 10:55 AM   #3
The Typhoon intake does offer more HP CAPABILITY than a Ford Racing PI. However this horsepower is acheived by shifting your RPM operation range to a higher RPM. If your engine is set up to run a higher RPM with the proper cam and valvetrain along with the proper set of heads then yes this intake will help improve your power numbers. If your heads and intake are stock then the Typhoon will most definatly kill your HP and Torque and you will lose performance ability rather than gain it.
DieselStang is offline   Reply With Quote
Old 03-27-2013, 10:58 AM   #4
Billymich's Avatar
+1 Well said.
Old 03-27-2013, 11:04 AM   #5
Xavier9370's Avatar
Thanks very clear answer. I have stock cams and heads so i will stick to bolts ons for now thanks guys.
06:01 AM
