99 mustang gt Fuel - Mustang Evolution
Old 03-27-2013, 11:27 AM   #1
99 mustang gt Fuel
I just put a new motor in my 99 gt but there is no Fuel getting to the engine. Do I have to Prime it ? Was working before the new motor went in
derrickk is offline   Reply With Quote
Old 03-27-2013, 04:11 PM   #2
02StangGT's Avatar
I put an 04 motor in my 02 and I just turned the key to acc but not all the way till it cranks. This allows the fuel pump to send gas to the rails. If you turn it to acc you should hear a faint buzz sound. Thats the pump pushing the gas.
02StangGT is offline   Reply With Quote
Old 03-28-2013, 07:05 AM   #3
tonyd01gt's Avatar
Hi, did you check your fuel pressure .did you change the fuel filter?
tonyd01gt is offline   Reply With Quote
Old 03-29-2013, 12:47 PM   #4
95v686gt's Avatar
Check the inertia switch in the trunk if the pump isn't running. Fuse would be next.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-29-2013, 01:40 PM   #5
Cornkush's Avatar
go on the fuel rail and there should be a fuel pressure release valve. turn key but don't start and it should some pressure fuel will come put if the pump is functioning
Cornkush is offline   Reply With Quote
12:07 PM
