2000 gt tranny rattle? - Mustang Evolution
Old 03-27-2013, 05:01 PM   #1
2000 gt automatic. I do need new brakes and disc. I just put in a new 4.6 engine. It was pulled from an older gt everything checked out fine with the motor until I took a 24hr trip to cali. I think that the tranny may need some lube, because when I go ~70 and let off the accelerator there is a grinding noise. When I shift to neutral the noise level is reduced significantly. Also when accelerating too much the noise is produced again. Any ideas to what may be the problem will help. Thanks.
Chaise-
Chaise33 is offline   Reply With Quote
Old 03-27-2013, 05:18 PM   #2
Billymich's Avatar
pilot bearing? Check ATF level. U-joints are the obvious place to st
Old 03-28-2013, 07:10 AM   #3
tonyd01gt's Avatar
Try checking your tranny mount, and also the ATF, U-joints.
tonyd01gt is offline   Reply With Quote
06:53 AM
