98 mustang - Mustang Evolution
Old 03-31-2013, 05:44 PM   #1
evergne's Avatar
98 mustang
Still deciding what I will do with my car. I have one of the heads broken in one of the spark plug threads. Should I do the coyote swap or work on the 4.6 engine and put better pistons, trick flow pi heads, bore the block and try to get to 400hp? What would be cheaper?
evergne is offline   Reply With Quote
Old 03-31-2013, 07:11 PM   #2
1996mustang's Avatar
coyote swap is not the cheaper of the options, atleast imo, since it requires diff motor mounts, a whole diff harness to make it work and alone the engine is 6k for a crate motor not including the pulley kit for it. imo i would do the pi heads or tfs pi heads, dont bore the block imo build the valve train to use atleast stage 2 cams forged internals, and im sure you would be at around 400hp.
Old 03-31-2013, 07:14 PM   #3
evergne's Avatar
Motor mounts are the same
01:50 PM
