Suspension overhaul - Mustang Evolution
Old 03-31-2013, 09:04 PM   #1
Tanker2012's Avatar
Suspension overhaul
• KYB AGX adjustable shocks and struts
• Maximum Motorsports caster/camber plates
• Steed X 2 ball joints
• Steeda bump steers
• Right Stuff Cobra 2-piston calipers, rotors pads
w/braided brake lines
• Prothane urethane bushings:
Steering rack
LCAs
Rear U&L control arms
• Rust busted and painted LCAs
• Rust busted and painted rear control arms
• New hardware all around
• Multiple trips to Ace, Harbor Freight, and Sears
• Busted knuckles
• Good times!!!
Ready for autocross next Saturday. I need to get it aligned but it's sitting sitting well. Next, drivetrain upgrades and more power...
ID:	99743   Click image for larger version
ID:	99745   Click image for larger version
Tanker2012 is offline   Reply With Quote
Old 03-31-2013, 09:07 PM   #2
fastmustangs1's Avatar
Thats a good plan. Id get the bump steer gauge when putting on the kit. JUst get a full alignment afterwards.
Also done the road look into a Panhard Bar and Full Legnth subframe connectors too.
Just my 2 cents.
fastmustangs1 is offline   Reply With Quote
Old 03-31-2013, 09:10 PM   #3
Tanker2012's Avatar
Just my 2 cents.
It's done. Getting aligned tomorrow.
---------- Post added at 09:10 PM ---------- Previous post was at 09:09 PM ----------
Are those the weld-in frame strengthens? I heard good things. Apparently SN95's straighten up a lot with them.
Old 03-31-2013, 09:10 PM   #4
Have them add neg camber and max out ur castor angles too.
Old 03-31-2013, 09:12 PM   #5
Tanker2012's Avatar
Will do.
Old 03-31-2013, 09:12 PM   #6
Yes subframe connectors are the way to go. I got mine fully welded in 8 yrs ago.
And is the best mod u can do to eliminate chassis flex under load.
Here is a pic of mine.
Old 03-31-2013, 09:13 PM   #7
Tanker2012's Avatar
I'm going to have them check all my torque specs etc. also while they're down there.
Old 03-31-2013, 09:15 PM   #8
Also a good set of rear lower control arms like Maxi Mo will make ur car launch better and reduce wheel hop issues. Leave the UCAs stock.
Old 03-31-2013, 09:15 PM   #9
Tanker2012's Avatar
Nice! I'm impressed about how clean your undercarriage looks. I went through a box of shop towels and 3 cans of brake clean and 2 cans of engine degreaser cleaning off the road grime. Looks better now. I used urethane spray paint for the LCA. Made it looked like a refurb (I guess it is really now).
Old 03-31-2013, 09:18 PM   #10
Im not sure how long KYBs will hold up to AutoX though. What springs r u using.
View my pics to see my setup.
Old 03-31-2013, 09:22 PM   #11
Tanker2012's Avatar
H & Rs Super Sports.
At some point I'm going to do a full coil over upgrade. Probably when these shocks/struts bite the dust. At least it will ride and handle better than new and certainly better than 16 yr old factories that have 75k miles on them.
Old 03-31-2013, 09:30 PM   #12
Boomdizzle's Avatar
Nice little lost if upgrades there. Little 2nd Christmas with the tax return? Lol
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-31-2013, 09:32 PM   #13
Im gonna throw my panhard bar on after axle rebuild.
Old 03-31-2013, 09:35 PM   #14
Tanker2012's Avatar
Yeah it was some. No not a tax return. Just finished remodeling the house for my wife so now I get to play. Plus graduating from MBA in May so I figure what the hell.
---------- Post added at 09:35 PM ---------- Previous post was at 09:33 PM ----------
Sweet. What brand? That's some serious race equipment.
Old 03-31-2013, 09:38 PM   #15
Im running Maxi Mo panhard bar. Going with FRPP 3.73 and an Eaton LSD.
12:19 PM
