Oil Leak - Mustang Evolution
Old 03-31-2013, 09:36 PM   #1
victorsmb's Avatar
Region: Mexico
Oil Leak
Hello! it's me again bothering everybody with my car! hahaha I'm having this issue with the engine oil :s
Yesterday I noticed a little pool of oil on my garage floor so I checked and realized that it was leaking only when the car is ON (little but continous drops) and is coming out of this piece (I'm guessing it's a sensor):
So I took it off and cleaned it, as shown below:
But now that I placed it back where it was, it's dropping a lot more oil (again, just when the car is ON) and is no longer just drops, but a continous "stream" of oil, I think I already lost half of the oil and I don't know if I can make it on time so I can take it to someone to get it fixed.
Do you think this may be caused because I didn't add that strange white tape (https://www.google.com.mx/search?hl=...mg.VlZa_o0hDwE) when re attaching the sensor??
All your help will be much appreciated, and thank you very much in advance!
victorsmb is offline   Reply With Quote
Old 04-01-2013, 12:13 AM   #2
Slow4V's Avatar
Use that white tape , can't spell it correctly..
Teflon tape I think
And that will fix your problem
Old 04-01-2013, 12:36 AM   #3
victorsmb's Avatar
Region: Mexico
Unfortunately I found out that what's wrong is actually the piece where the sensor goes in, in this picture those red lines indicate cracks that this piece has, I think I have to replace the whole thing :S
Old 04-01-2013, 08:00 PM   #4
BigB227's Avatar
I'm glad you posted this because I've been having a bad oil leak problem and I'm pretty sure that I'm leaking from the exact place you are too, does anyone know the part name for that? So I can replace it?
BigB227 is offline   Reply With Quote
Old 04-02-2013, 10:26 PM   #5
1996mustang's Avatar
Oil cooler. Thars what it really is cause it has coolant lines goin intp it
---------- Post added at 12:26 AM ---------- Previous post was at 12:25 AM ----------
But if anything try oil filter housing as a description
Old 04-03-2013, 01:01 PM   #6
BigB227's Avatar
Oh ok thank you very much
Old 04-03-2013, 10:56 PM   #7
victorsmb's Avatar
Region: Mexico
Do you know where can I get this part? the oil filter housing
Old 04-03-2013, 11:07 PM   #8
Justasix98's Avatar
Check your local O'Reillys/AutoZone/Napa/ect..
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 04-03-2013, 11:16 PM   #9
victorsmb's Avatar
Region: Mexico
No luck in any of those, it's actually really hard to find it, I'm having a lot of trouble :s
Old 04-03-2013, 11:23 PM   #10
2 places....dealer or junkyard
07:52 PM
