Need some help!! - Mustang Evolution
Old 04-01-2013, 03:22 PM   #1
BigB227's Avatar
Question Need some help!!
I have a constant code P0174 that keeps popping up and refuses to go away. I experience no driveability problems and nothing other then the annoying check engine light. The code reads "System too lean Bank 2" I have cleaned my mass airflow sensor due to the oil from the air filter oil. light is still there. i replaced both upstream O2 sensors and the light came back. As far as i can tell or hear i do not think that i have a vaccuum leak anywhere. I have replaced the fuel filter and fuel pump(which needed replacing due to failing on me) and still this code appears. I am completely lost at what else there is i can do. Im also tired of throwing money and "hoping" that it fixes it. Does anyone here have any advice or experience into something that is causing it?
BigB227 is offline   Reply With Quote
Old 04-01-2013, 03:27 PM   #2
Had this same problem on my 08. Look at your camshaft position sensors. They are known to go bad on pre 05 mustangs. Also check your oil level. My oil was running low and threw that same code until I corrected my oil level.
jazzystang is offline   Reply With Quote
Old 04-01-2013, 03:29 PM   #3
BigB227's Avatar
hmmmm i hadnt thought about that, Thank you very much! i will check both and post an update later if these are fixes to the problem
Old 04-01-2013, 03:37 PM   #4
BigB227's Avatar
Might be a dumb question but is there only one camshaft position sensor or two??
Old 04-01-2013, 04:01 PM   #5
It should be two. And they are fairly cheap at parts stores. Usually about $20 each.
Old 04-01-2013, 07:51 PM   #6
BigB227's Avatar
Alright thank you )
05:02 PM
