What spark plugs are the best? - Mustang Evolution
Old 04-01-2013, 07:29 PM   #1
Allans03ragtop's Avatar
What are the best plugs for my 03 GT?
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 04-01-2013, 09:24 PM   #2
i would go with the pul/star spark plug thats what i use its a bit prices at any where between 13-14 dollars but well worth it another good one is Bosch
rajeev2liz is offline   Reply With Quote
Old 04-01-2013, 09:46 PM   #3
2300turboford's Avatar
Any iridium works like Ngk ...etc just don't buy e3 spark plugs
Old 04-02-2013, 12:57 AM   #4
02mineralgreygt's Avatar
Stick with original. Our motors like to be picky at times as I found out.
02mineralgreygt is offline   Reply With Quote
Old 04-02-2013, 01:07 AM   #5
Venomouz831's Avatar
Oem
)02 Gt, Founder of WE2G
Old 04-02-2013, 01:14 AM   #6
1slosix's Avatar
oem service plugs...$5 a pop on average and always work like a charm
carving corners like a boss
Old 04-02-2013, 03:59 AM   #7
Thanks guys. Has anyone had a problem with them blowing out if the block? I read that that is common with the 4.6. Do you have to remove the fuel rail to change them?
Old 04-02-2013, 04:25 AM   #8
jdavis96gt's Avatar
Region: West Virgina
Copper tipped motorcraft
Old 04-02-2013, 10:02 AM   #9
yea that is a common problem on our cars but i havent had it happen...(knock on wood) and you shouldnt have to remove the fuel rails.
Old 04-02-2013, 10:07 AM   #10
Thanks everyone
Old 04-02-2013, 10:13 AM   #11
1lowGT's Avatar
Yup motorcraft is what i got
Old 04-02-2013, 10:26 AM   #12
Mzilla's Avatar
Bosch are the worst plugs made even for my BMW. I use NGK TR6 in a high boost application.
If your car is bolt on modded stick with the OEM motorcraft plugs.
---------- Post added at 11:26 AM ---------- Previous post was at 11:24 AM ----------
Your car has the 7/8 thread Romeo heads and you will not have any issue. The early Windsor heads had on 4/5 threads and were more prone to blow out. Also make sure the use some anti seize on the plugs treads and you will be good.
Mzilla is offline   Reply With Quote
Old 04-02-2013, 10:54 AM   #13
1lowGT's Avatar
I had a problem with the thread stripping on one, from either over tightening which i don't think we tightened them that tight, or he said carbon build up and while tightening them messed the threads. But its all fixed now. He said that they are known for that though.
Old 04-02-2013, 12:38 PM   #14
Region: Arkansas
There's no need for iridium plugs in these motors unless you have serious work done.
It's just extra money thrown away for a fancy electrode and brand name.
BackPressure is offline   Reply With Quote
12:17 AM
