Having a problem, help? - Mustang Evolution
Old 04-02-2013, 07:23 AM   #1
Ryder53's Avatar
Region: Montana
Okay I have a 2003 mustang gt. this morning I went out and noticed my mileage lights were still on along with the air bag light. So I blamed it on the cold weather. I got to work and turned the car off and those lights never turned off. The mileage lights have no numbers displayed but are dots, and the air bag light is dim but not off...I have no idea what's wrong? Should I try disconnecting the battery for an hour and see what happens? I need help please.
Ryder53 is offline   Reply With Quote
Old 04-02-2013, 04:00 PM   #2
tonyd01gt's Avatar
If you have another key try it. Seem to be something with your PATS
tonyd01gt is offline   Reply With Quote
Old 04-02-2013, 04:43 PM   #3
Definitely start with disconnecting your battery and letting the car reset itself. Check the fuse too.
jazzystang is offline   Reply With Quote
Old 04-02-2013, 06:46 PM   #4
Ryder53's Avatar
Region: Montana
I only have 1 key. And I disconnected it, that didnt work. But I haven't checked fuses yet
Old 04-02-2013, 06:59 PM   #5
dylanmullins's Avatar
If you are going to go into your PATS system you will need a minimum of two keys
dylanmullins is offline   Reply With Quote
Old 04-02-2013, 10:39 PM   #6
Ryder53's Avatar
Region: Montana
The car wouldn't start, had to get it jumped..then it died when I parked..gonna get the alternator tested tomorrow..hoping that's it. Fingers crossed!
Old 04-03-2013, 06:05 AM   #7
Get the battery tested too.
Old 04-03-2013, 10:05 AM   #8
Ryder53's Avatar
Region: Montana
Theft light flashes really fast when I try to start it
Old 04-03-2013, 10:13 AM   #9
The PATS light? If that's the case you need to reprogram your keys.. you need two keys to do that
---------- Post added at 10:13 AM ---------- Previous post was at 10:13 AM ----------
Our security light should I say?
Old 04-03-2013, 03:53 PM   #10
CAMARO_KILLA's Avatar
i would call a locksmith. like the other guys said its prob not ur battery or alternator. I know Fords(dont know about anyone else) theft system stuff is really sensitive. somebody may have tried to break in your car last night, or possibly got in and tried to start it and your theft system is keeping it from run ing today. i have seen that happen before
CAMARO_KILLA is offline   Reply With Quote
Old 04-03-2013, 04:58 PM   #11
Ryder53's Avatar
Region: Montana
Yes but the key would make it so it would not turn over at all. It will run. But not for long
Old 04-03-2013, 05:45 PM   #12
Reprogram the keys! Problem solved. I have seen that happen numerous times. I work at a ford dealership and that has happend a lot. If.someone tried a different key in yhe ignition that will happen and you will have a security code in your car that will have to be erased and 2 keys programmed.
Old 04-03-2013, 06:10 PM   #13
White03GT's Avatar
+1
White03GT is offline   Reply With Quote
Old 04-03-2013, 10:30 PM   #14
Ryder53's Avatar
Region: Montana
Found the problem..the alternator was only putting out 30 amps..really really sucky hah
01:00 AM
