Clutch cable suggestions?? - Mustang Evolution
Old 04-02-2013, 09:33 AM   #1
CodyNelson's Avatar
Region: West Virgina
I have a 2000 GT with a vortech blower and 3.73 gears. I will be using a Maximum Motorsports quadrant and a firewall adjuster (so cable doesn't have to be adjustable). I want ones that you all have tried and that don't stretch like some crappy aftermarket cables do
Old 04-02-2013, 11:31 AM   #2
cliffyk's Avatar
I have been running the ATP cable from Advance Auto Parts ($69) for nearly 2 years, with a RAM HDX clutch (rated for 450 lb-ft)--with no problems of any sort.
My OE cable was damaged by a sharp edge on an aftermarket quadrant (read more about that here). Needing a replacement NOW and fully prepared to order a Ford cable down the road (no pun intended), I bought the ATP cable--however I found it to be just as good as the OEM unit, well made from good materials, and never ordered the Ford cable--that was 45k miles ago...
Old 04-02-2013, 11:33 AM   #3
Oem or equivalent
Old 04-02-2013, 11:38 AM   #4
stick with the OEM cable, I believe maximum motorsports modifies stock cables but not sure
Old 04-02-2013, 11:54 AM   #5
CodyNelson's Avatar
Any reviews on the steeda cable?
Old 04-02-2013, 01:06 PM   #6
03RedfireGt's Avatar
Heard some bad reviews on the steeda cable. Maximum Motor Sports +1,
03RedfireGt is offline   Reply With Quote
Old 04-02-2013, 02:03 PM   #7
CodyNelson's Avatar
Ok thanks guys!
Old 04-02-2013, 09:38 PM   #8
CodyNelson's Avatar
Maximum Motorsports Quadrant, cable, and firewall adjuster have been ordered! Next paycheck will be clutch and flywheel!
Old 04-02-2013, 10:27 PM   #9
Lorraine's driver
ab_mach1's Avatar
Oem or equivalent
Tried and true. OEM has a long history of being better than the rest. I'm switching out my FRPP adjustable cable later this spring/summer, even though it's got ~3,000 miles on it.
Good choice! I'm pretty sure the Maximum Motorsports kit uses an OEM cable.
Clutch Cable, Quadrant, and Firewall Adjuster Package
Info on the MM cable
Instagram: @ab_mach1
05:18 PM
