Strong fuel oder - Mustang Evolution
Old 04-03-2013, 03:04 AM   #1
Polar Bear's Avatar
Region: Asia
Strong fuel oder
I have a string fuel smell in the compartment of my car when driving. Ha it when I bought it last August and thought it was only running rich. Got a tuner from AM and after uploading the street 93 tune the smell went away and the engine ran better. Changed the oil the other day and now the smell is back. Tune is the same. Only other variable is the outside temps are starting to warm up. 40s vice 20s. Any ideas?
Steve
Polar Bear is offline   Reply With Quote
Old 04-03-2013, 03:06 AM   #2
98vertgt's Avatar
Check the fuel filler neck seal that goes into the side of the fuel tank. Mine went bad last week. It's very common
98vertgt is offline   Reply With Quote
Old 04-03-2013, 03:34 AM   #3
Polar Bear's Avatar
Region: Asia
Really? Never would have thought of that. I was thinking fuel filter.
Steve
Old 04-03-2013, 04:16 AM   #4
98vertgt's Avatar
Take a look, it took me a little while to find it but it was pretty easy
Old 04-03-2013, 05:03 AM   #5
Polar Bear's Avatar
Region: Asia
You actually had a leak from that location?
Steve
Old 04-03-2013, 06:11 AM   #6
cliffyk's Avatar
As stated above, it is common for the filler neck to rust through on "rust belt" cars. Dirt and debris collect under the corrugated plastic cover, trapping moisture and the cancer follows:
This is from a Northern friend's car:
Removing the plastic condom and spraying the tube with a anti-rust product like LocTite Extend may catch it in time.
My '03 has been and will be a Florida car for its whole life but I still removed the cover and shoot it with Extend once a year or so...
Old 04-03-2013, 06:54 AM   #7
Polar Bear's Avatar
Region: Asia
Assuming (not arguing with CliffyK by any means) that it is this how would I find a replacement? Problem is I am in Japan. I will have the car on a lift Saturday and be able to take a look. Thanks for the help everyone.
Steve
Old 04-03-2013, 07:59 AM   #8
98vertgt's Avatar
I'm talking about the actual rubber grommet that goes in the side of the tank where the filler neck goes. My car doesn't have an ounce of rust underneath.
Old 04-03-2013, 03:02 PM   #9
Polar Bear's Avatar
Region: Asia
Ok. Certainly will look there too. Thanks again.
Steve
08:23 PM
