How can i tell the # on the cylinders? - Mustang Evolution
Old 04-03-2013, 08:30 AM   #1
Rich04's Avatar
Where is #7 cylinder and injector located? 2004 GT
Rich04 is offline   Reply With Quote
Old 04-03-2013, 08:45 AM   #2
maldog's Avatar
Region: Nevada
Rear
4. 8.
3. 7.
2. 6.
1. 5.
Front
---------- Post added at 07:45 AM ---------- Previous post was at 07:43 AM ----------
Front is you standing in front of the car looking at the engine.
This is your firing order.
Firing order is 1-3-7-2-6-5-4-8
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-03-2013, 08:54 AM   #3
Rich04's Avatar
Originally Posted by maldog View Post
Rear
4. 8.
3. 7.
2. 6.
1. 5.
Front
Thanks, im getting a miss at start up and it says also my # 7 injector thats the same spot as the spark plug rite?
Old 04-03-2013, 09:04 AM   #4
maldog's Avatar
Region: Nevada
Correct.........your injector is right by the cylinder plug.
---------- Post added at 08:04 AM ---------- Previous post was at 08:02 AM ----------
You can also switch one of your coil on plug to number 7 and run it to see if you now get a fault code where you put #7 COP. Clear your codes before starting engine.
Old 04-03-2013, 09:08 AM   #5
Rich04's Avatar
Yeah i'm gonna try that first, also should i try moving the injector?
Old 04-03-2013, 09:12 AM   #6
maldog's Avatar
Region: Nevada
You can, but I would do the COP first. When you put your injector back in lube the oring with some dielectric silicone grease so you don't tear the oring.
Old 04-03-2013, 09:40 AM   #7
Rich04's Avatar
Alright, is the Oring on the end of the injector ? Not into the side of the fuel rail cause i remember one doing my intake manifold and one had a tear in it.
Old 04-03-2013, 09:45 AM   #8
maldog's Avatar
Region: Nevada
Yes they are on the injector.
Old 04-03-2013, 09:48 AM   #9
Rich04's Avatar
Yeah mine had a tear in it, soo do i have to get a new injector? Or can i get the oring?
Old 04-03-2013, 10:03 AM   #10
BeasGT's Avatar
I'm having the same exact problem.
I'm having misfire on #7
My clip on the coil is broken
BeasGT is offline   Reply With Quote
Old 04-03-2013, 10:10 AM   #11
Rich04's Avatar
Which side of the connecter is cracked? The wire connecting or the coil pack?
Old 04-03-2013, 10:30 AM   #12
BeasGT's Avatar
The clip that's connecting the coil pack
Old 04-03-2013, 01:34 PM   #13
maldog's Avatar
Region: Nevada
You should be able to buy the oring. Check your local auto parts store or dealer.
Old 04-03-2013, 02:06 PM   #14
Rich04's Avatar
Thanks man im going to pick them up from pepboys. Some idiot told me " it dont matter if its cracked a little bit and said id need a new injector it self. Could this cause the code coming up ?
Old 04-03-2013, 02:58 PM   #15
maldog's Avatar
Region: Nevada
What's cracked? If your talking about the oring? Yes it could cause your problem.
Old 04-03-2013, 03:56 PM   #16
Rich04's Avatar
Yes the oring
Old 04-03-2013, 06:15 PM   #17
Rich04's Avatar
Not the oring, i need the pintle cap where can i get one auto store dont seem to crappy them
Old 04-03-2013, 06:47 PM   #18
maldog's Avatar
Region: Nevada
You might want to try a Ford dealer or eBay.
Old 04-03-2013, 07:09 PM   #19
Rich04's Avatar
Late model restoration got em
Old 04-04-2013, 08:04 AM   #20
maldog's Avatar
Region: Nevada
I think this will work for you.
Ford Lincoln Mercury Fuel Injector Service Repair Kit O Rings Pintle Caps Seals | eBay
Old 04-04-2013, 08:06 AM   #21
Rich04's Avatar
Thanks just ordered them. Is it possible this is the problem?
Old 04-04-2013, 08:15 AM   #22
maldog's Avatar
Region: Nevada
Yes it's possible. Did you try the other test already?
Old 04-04-2013, 08:26 AM   #23
Rich04's Avatar
Yeah. One of my coils is broken it doesn't screw down all the codes are off says im running lean was told to run seafoam and change my fuel filter went ahead and got the foam and a motor craft filter gonna do it today see what happens
Old 04-04-2013, 09:04 AM   #24
maldog's Avatar
Region: Nevada
Ok, keep the updates coming. I hope it goes good.
Old 04-04-2013, 09:10 AM   #25
Rich04's Avatar
Will do gonna do the foam as soon as i get out of work, thanks
Old 04-04-2013, 02:24 PM   #26
Rich04's Avatar
Haven't changed the filter yet but the idle has gotten a lot better with just the foam !
Old 04-04-2013, 08:16 PM   #27
maldog's Avatar
Region: Nevada
That's good.
Old 04-06-2013, 09:37 AM   #28
Rich04's Avatar
MAF is bad -_-
Old 04-06-2013, 07:55 PM   #29
maldog's Avatar
Region: Nevada
MAF is bad -_-
Good & bad.....easy fix
Old 04-06-2013, 09:39 PM   #30
Rich04's Avatar
Called some auto part stores 120$ found one online for 40 tho
Old 04-07-2013, 09:01 PM   #31
maldog's Avatar
Region: Nevada
I have one in my parts bin as a back-up I bought on eBay for $40 probably from the same place
07:22 AM
