Check engine light codes, Misfire & ignition coil. - Mustang Evolution
Old 04-03-2013, 10:05 AM   #1
BeasGT's Avatar
Check engine light came on and these codes came out.
Anyone know how to fix this?
BeasGT is offline   Reply With Quote
Old 04-19-2013, 10:50 PM   #2
Engine light on
Auto Zone pluged in reader came up w/Duralast SU2327 cam sensor 422332.20$.
Didn't try it yet. Tomorrow. Let u know.
---------- Post added at 12:50 AM ---------- Previous post was at 12:46 AM ----------
AutoZone plugged in reader says install SU2327 CamSensor. Will try it tomorrow
CRASHG63 is offline   Reply With Quote
Old 04-20-2013, 11:31 PM   #3
1996mustang's Avatar
The misfire is on cyl 7 probably a bad coil from the looks of it. Clear thw code and swap a good coil say #5 with #7 and see if p0355 and p0305 show up uf so u know its a bad coil
Old 04-21-2013, 06:10 AM   #4
My 05GT ENGINE LIGHT ON CONSTANT. AutoZone code reader recognized it and came up w/a Duralst Pt #, SU2327 which is 1 bolt w/a female plug in plastic bolt on. 85k onGT.
Thx for reply!
Old 05-05-2013, 12:11 PM   #5
Thx for reply!
Code was P0340. AZ said translates to fix with "camshaft position sensor" SU2327. Installing Friday Afternoon.
Old 06-01-2013, 02:00 PM   #6
Didn't post the eventual fix here. It was the cam phaser left bank. I.e., like a timing chain. Cost me $600+.
Worth it. Will for sure be my last new car.
First new mustang a 64 1/2 white 289 fast back w/redlined. One of the many fords I have owned.
46 coupe, 50 coupe I customized, dethroned, fat blue stripe down side on off white.. 3 two barrel.Strombrrg? Carbs. Could spin rears when I popped it into second.
check engine
10:12 PM
