Resealing Headlight Housing - Mustang Evolution
Old 04-04-2013, 01:54 PM   #1
Michael.s.king's Avatar
Region: Maine
I have some moisture in one of my headlights and was going to take it out and try to reseal it today. I was just wondering if anyone has done this and what they used to reseal it. Also, how'd you get the moisture out? Can you just simply wipe out the moisture and let it dry inside? Has anyone done this for a taillight? Thanks in advance!
Michael.s.king is offline   Reply With Quote
Old 04-04-2013, 02:11 PM   #2
fastmustangs1's Avatar
Drill 2 holes 1/4in in each of the bottom of the housing. Then get some RTV sealant from your local auto parts store. Seal the edges real well and let it dry over night and your done.
fastmustangs1 is offline   Reply With Quote
Old 04-04-2013, 06:23 PM   #3
Region: Maine
Anyway to do it with out drilling? Thank you!
Old 04-04-2013, 07:06 PM   #4
Region: Maine
Is this normal? Looks like some kind of drain hose?
ID:	100508   Click image for larger version
Old 04-04-2013, 08:53 PM   #5
Yes now drill 2 holes on the bottom of the housing then seal the edges.
Old 04-04-2013, 09:45 PM   #6
Doe_Rae_mi's Avatar
U dont have to drill just blow a hair dryer in it
Old 04-04-2013, 09:59 PM   #7
I too tried that but it doesnt completely get all the water out though. That is
y I drilled one hole on each side of the housing.
Old 04-04-2013, 10:25 PM   #8
Slow4V's Avatar
It will take forever to blow the water out
Just get new headlamps
Old 04-04-2013, 10:26 PM   #9
Region: Maine
Sweet thanks guys, that rvt silicone stuff is pretty sweet. Gonna put the headlight back in tm morning, hopefully it will be alright!
Old 04-05-2013, 06:08 AM   #10
jdavis96gt's Avatar
Region: West Virgina
I had this problem 2 weeks ago. Took toilet paper cardboard thingy and stuck around where bulb goes in and let hairdryer blow in. I didn't take headlight out. It took bout hour and a half to get all the moisture out. After u get all moisture out, go get clear silicone. If u wet your finger the silicone wont stick to your finger.
Old 04-05-2013, 06:40 AM   #11
Region: Maine
Well, I used a blow dryer to get most of it out and the put the silicone around all the edges. I let this dry over night. This morning all the moisture was gone, but I think the blow dryer dried (instead of it naturally evaporating?) and now there are like small water marks on the inside of the headlight. It isn't a huge deal, seems like it works for now and I will prob just get a new headlight if the water comes back. Thanks for the help guys
Old 04-05-2013, 07:00 AM   #12
jdavis96gt's Avatar
Yea mine has couple water marks but its dry lol, been 2 weeks. Good luck
Old 04-28-2013, 09:54 AM   #13
Region: Maine
Just a little update, I took my headlight out and let it air out and I took a blow dryer to it. It dried with water marks but now the water marks are gone and no moisture in my headlight anymore! Used that clear silicone. Worked great
07:54 PM
