Steering Noises (Video) - Mustang Evolution
Old 04-05-2013, 03:16 PM   #1
EthanGT03's Avatar
The first one with the hissing type noise just started today. And second one with creaking noise has been happening for a long time. Any ideas?
http://youtu.be/ut8AuuTD5eU
EthanGT03 is offline   Reply With Quote
Old 04-05-2013, 03:56 PM   #2
Creaking is steering rack bushings.
Old 04-05-2013, 05:11 PM   #3
EthanGT03's Avatar
Okay any idea on the hissing?
Old 04-05-2013, 05:30 PM   #4
Voltage258's Avatar
Region: Utah
Agreed sounds like bushings. I had a similar sound on my old jeep. If you look at them and they look fine, spray them down with some white lithium grease or something and see if that helps.
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
And I could not hear hissing.?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 04-05-2013, 05:31 PM   #5
Couldn't really make out a hiss on the phone
Old 04-06-2013, 02:33 AM   #6
EthanGT03's Avatar
Maybe hissing was the wrong word. It's like rubber rubbing or something. It's very noticeable in the video. The sound before I turn the car off
Old 04-06-2013, 08:03 AM   #7
JCOB72's Avatar
Mine made a similar sound and it was the ball joint.
JCOB72 is offline   Reply With Quote
Old 04-09-2013, 07:51 AM   #8
v8pony's Avatar
I had the exact same creaking, turned out it was coming from my tie rod end boot..being my tie rod was still good (had zero play) I didn't want to replace it yet. So I took a can of white lthithim grease, attached the red straw to the can, than pop the red straw into the tie rod end boot and filled her up with grease, I seal back the tiny needle hole with a dab of silicone, and boom dead quiet going on a month now ! Pretty sure I still have the video I made to show my buddy how to fix it, if I come across it ill drop it here for ya
2002 5spd GT
Feb 2013 Mustang of the Month
Old 04-09-2013, 02:55 PM   #9
EthanGT03's Avatar
That's be awesome if you have it so I could give it a shot. I happen to have some white lithium freeze aswell
Old 04-09-2013, 05:11 PM   #10
v8pony's Avatar
Couldn't find it but this is it I found a similar video on YouTube, I just didn't use super glue nor did I use duct tape lol, I poked the red straw through the boot, shot it up with grease, removed the red straw (grease did come out of the hole so I knew it was full in there), cleaned it all up, than took a small dab on my fingertip of high temp silicone and covered the needle sized hole..that's it done, been quiet for a month now.
2002 5spd GT
Old 04-10-2013, 12:26 PM   #11
fastmustangs1's Avatar
Thats a ball joint dude. Id have that checked out right away. CHeck to see if the boots r torn on both ball joint and tierod ends.
fastmustangs1 is offline   Reply With Quote
Old 04-10-2013, 01:21 PM   #12
I agree, sounds like a ball joint is dry and doesnt have grease in it. But to rule out the rack I would get all of your p/s fluid out and replace it with lucas p/s fluid because of the seals. Once you change the fluid move the wheel back and forth a few times and see if it gets goes away. I would def say ball joint here though.
southernstang00 is offline   Reply With Quote
02:30 AM
