Fuel pump replacements - Mustang Evolution
Old 04-06-2013, 12:43 PM   #1
Count Dragula's Avatar
What fuel pump do y'all recommend? Can I upgrade and it still run good? I have just basic bolt ons now. Intake, exhaust, gears. Should I just do a stock replacement or go ahead and upgrade for when I supercharge it?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-06-2013, 01:17 PM   #2
Mfore33's Avatar
Go with svt focus pump
Old 04-06-2013, 01:28 PM   #3
Will it make my check engine light go on?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-06-2013, 01:42 PM   #4
ksrumbel's Avatar
I just replaced mine today. I just went with a stock replacement. I got the whole assembly so I skipped out on the svt focus pump. No need for that unless you plan an going FI in the near future.
ksrumbel is offline   Reply With Quote
Old 04-06-2013, 03:28 PM   #5
What was the name of the pump you got?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-06-2013, 03:51 PM   #6
ksrumbel's Avatar
I just went to advance auto. I think it is an airtech?? The car runs now so I am happy.
Old 04-06-2013, 03:58 PM   #7
Haha mine still runs but it's rough when it's low on gas
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-06-2013, 05:57 PM   #8
Mzilla's Avatar
I would put in a single Ford GT pump. I run twin Ford GT pumps in a Fore fuel hat with dual FPDM and 10ga wiring.
ID:	100996   Click image for larger version
Mzilla is offline   Reply With Quote
Old 04-06-2013, 06:04 PM   #9
Would that be enough for when I put a kenne bell on it?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-06-2013, 08:07 PM   #10
Mzilla's Avatar
You can use a single GT supercar pump and a Kenne Bell BAP and get to the 475-500 rwhp safely. Any thing really over 500rwhp I would recommend twin pumps.
Old 04-06-2013, 08:40 PM   #11
onesickstang01's Avatar
Did you have an issue with pump depth? I had to trim my fuel hose from the hat to the pump and move the pumps as far toward the top of the hat as possible and even then had to beat the tank down slightly. Other than that the fore hat is a very nice peice and flows a ton of fuel with dual fpdm/wire upgrade/8an lines to rails
And to OP
Walbro makes a nice pump replacement for returnless setups now. Just sold my old pump but it was a walbro tu229hp. Made 425rwhp safely. Added a BAP to safely make 450. Not sure what it would have held up to but i went dual pump to crank boost up high
onesickstang01 is offline   Reply With Quote
Old 04-07-2013, 06:48 AM   #12
Rm360's Avatar
And to OP
Did you use the GT fuel tank? I think Mzilla has a cobra tank, I thought the Fore fuel hat was supposed to be a direct swap on a GT without any modification to the tank?
Old 04-07-2013, 06:54 AM   #13
Yea i have a gt tank that i baffled myself. The fore hat should be a direct swap, which is why i had asked if he had any issues with his swap. No difference in tank depth from gt to cobra tanks though. Done plenty of swaps from cobra pump hats into gt tanks as well as cobra tank swaps and no difference besides baffling. I just figure maybe fore fuel hose was cut slightly longer for smaller pumps than the supercar pumps
Old 04-07-2013, 07:05 AM   #14
Rm360's Avatar
Cool!!! I've had my eye on that fuel hat for a while its good to know there's no issues with it fitting !
Old 04-07-2013, 08:17 AM   #15
Cornkush's Avatar
Did this last week to my brothers 98 gt. isn't to bad if a job as long as you have an empty tank ours was a little ovr 1/4 lol
Cornkush is offline   Reply With Quote
Old 04-07-2013, 08:45 AM   #16
Mzilla's Avatar
My hat is the new design and has no hose on the end. The pump slips straight in to a nipple which is billet with a rubber o ring
Old 04-07-2013, 08:56 AM   #17
Cornkush's Avatar
Pics?
Old 04-07-2013, 09:11 AM   #18
Mzilla's Avatar
Originally Posted by Cornkush View Post
Pics?
Notice how the pump nipple go straight in to the hat with no hose it is pressed in.
Old 04-07-2013, 09:15 AM   #19
Cornkush's Avatar
Interesting mine was the old style.
Old 04-07-2013, 11:01 AM   #20
Mine was the old style as well. Looks like with the new style i would have been screwed
Old 04-07-2013, 11:57 AM   #21
Mzilla's Avatar
Why would you have been screwed
Old 04-07-2013, 12:01 PM   #22
No adjustability of pump height. Your pumps are stationary where they are because of the design. With mine i was able to add or subtract amount of hose between the hat and pump, which in my case had to cut as much out as possble and move the pump as close to the hat as it could go. Looks like that block is too deep and wouldnt allow my pumps to sit high enough. Obviously thats just going by looks though
Looks like you stayed returnless though... What kind of power did you make? And are you running dual fpdm or single modded?
Old 04-07-2013, 01:35 PM   #23
Mzilla's Avatar
You can adjust the pump height about a half inch in the hat. I run twin GT pumps with dual FPDM 10 ga wiring 8 an line 60lb injectors .I am currently making 587rwhp pulling it to 7400rpm. My next project is to add a water/meth kit so I can have a safe 600+ on pump gas.
Old 04-07-2013, 02:03 PM   #24
Sounds exactly like my setup. Made 576 on mine with a very conservative base tune for 91 right now. Probably going next week to get a final tune for 93. Had some BOV and IAC issues that i had to take care of
Old 04-07-2013, 07:00 PM   #25
taylor98gt's Avatar
What kinda fi you running?
taylor98gt is offline   Reply With Quote
12:07 AM
