front calipers not releasing - Mustang Evolution
Old 04-06-2013, 05:41 PM   #1
jdavis96gt's Avatar
Region: West Virgina
My front calipers are hanging up. If I pop brake hose on passenger side it release both sides. If I let it sit for about 10 hours, they release their self.
I've replaced caliper, master cylinder,brake hose on passenger side.
I'm thinking brake booster or proportioning valve. Only outside brake pad is froze to rotor. Inside bad isn't touching rotor at all.
Please help
Old 04-06-2013, 11:55 PM   #2
fastmustangs1's Avatar
Sounds like the slider pins are not greased and hanging up in the caliper.
fastmustangs1 is offline   Reply With Quote
Old 04-07-2013, 12:11 AM   #3
jdavis96gt's Avatar
They're greased. Both front calipers freeze up. One caliper is new and one factory.
Old 04-07-2013, 06:37 AM   #4
Rm360's Avatar
Did you bleed the system after you changed your parts???
Old 04-07-2013, 06:52 AM   #5
jdavis96gt's Avatar
I've bleed them couple different times. Strong clear stream. A mechanic friend said proportioning valve but I think that's his stab in the dark.
---------- Post added at 08:49 AM ---------- Previous post was at 08:48 AM ----------
Its like they're holding pressure but only the outer pad.
---------- Post added at 08:52 AM ---------- Previous post was at 08:49 AM ----------
Is inner pad and outer pad the same? Could they ne backwards?
Old 04-07-2013, 06:54 AM   #6
Rm360's Avatar
Are you just bleeding at the caliper? This happend to me once and I had to bleed that side from the master cylinder,
Old 04-07-2013, 06:54 AM   #7
Mfore33's Avatar
If air is in the rear lines it could migrate into the front during. Operation. I would take to shop where they can put a vacuume on the lines and pull out all old fluid and replace with new fluid then go from there.
Old 04-07-2013, 07:02 AM   #8
jdavis96gt's Avatar
I've bleed everything but MC about 3 times. Starting at the pass rear. I just read thread about unhooking brake petal from MC. It was 4 eye stang that did 5 lug converstion. Something about adjustment of a rod? His prob are exactly like mine.
04:24 AM
