Stupid noise - Mustang Evolution
Old 04-06-2013, 10:44 PM   #1
Defying_Fate's Avatar
Stupid noise
So lately I've been hearing a squeeking when I hit bumps. I want to say its something in the front end. But when I'm still and turn the wheel. There is no noise. Only when driving down the road. What Could it be? Ball joint? Tie rod? Something just need to be greased. Need somebody's help.
Defying_Fate is offline   Reply With Quote
Old 04-06-2013, 11:27 PM   #2
I can pick up so many noises that my car makes... If I focused on all of them it would drive me CRAZY. I just turn up the radio now. Besides, mustangs are fairly noisy. But if it's something you can't stand then I would try to fix it. Maybe its something with your transmission? Since you said its not noisy staying still
ThatsCoolBro is offline   Reply With Quote
Old 04-06-2013, 11:33 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Same here its annoying mine quite but load at the same time..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-06-2013, 11:44 PM   #4
fastmustangs1's Avatar
Could be a front control arm bushing needing grease perhaps. If u hear it when you turn the front wheels it could be a bad ball joint. If it is a bad joint get it fixed right away could be disastrous if it fails. You can check them by raising the front and at the 12 and 6 position grab the tire and see if there is any movement. Then do 9 and 3 position to check the tierod ends. Also check the rubber boots on the ball joint and tiered ends to see if they r torn any.
fastmustangs1 is offline   Reply With Quote
Old 04-06-2013, 11:46 PM   #5
Yea that's what I plan on doing. Gotta get it up on a lift in the next couple days. Been reading around and everyone's been saying it could just need to be greased. Because I can turn the wheels and there's no noise.
Old 04-06-2013, 11:48 PM   #6
A bad ball joint will sound like pulling a rusty nail out when u turn the front tires.
Just have ur control arm, sway bar bushings greased then go from there.
Old 04-06-2013, 11:48 PM   #7
slow281
sixpac's Avatar
Region: Nebraska
How do you grease them..
2001 GT - True Blue
Old 04-06-2013, 11:51 PM   #8
CHeck to see if there is any play in the ball joints and tierod ends. If the boots are torn they wont hold grease. They will need replacing.
10:35 PM
